After iOS 8 upgrade Apple iTunes I'd and iCloud id do not match. iCloud I'd will not accept my password. Need to delete iCloud but it does not come up with option to delete...only sign out and will not let me do either since it won't accept my password. Will not accept answers to security questions or birthdate either
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
SOURCE: how to creat an apple ID
Just create a new free email account and then register it to AppStore ( or iTunes)
SOURCE: how do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
SOURCE: delete photos from my apple ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to remove the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More detailed guide about how to delete photos from iPad.
www.iphone-mac.com/how-to-delete-photos-from-ipad-camera-roll.html
