When I go into the menu to set the channels, the channels won't set and the only channel that will set is 5. How do I set the other channels?
SOURCE: I lost the remote and cant find a universal that
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
SOURCE: Channels 3, 4, 5, and 7 are mute. The mute button has no effect.
there should be an audio section of your tv
Go through each of your setting s and be sure nothing was changed. goto setup and reset to factory settings. your TV will do something funky and powercycle.
THAT should fix your problem.
if not, is your cable service through your VCR? if so, remove the vcr altogether and connect your cable services directly. All should now be a go.
SOURCE: I have an Element 32
I talked to the manufacturer & they said that all I needed to do was to run the channel search, uninterupted, again. I did it & everything works. Thank you for your input.
