Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
A
Anonymous Posted on Oct 11, 2014
Condensed dryer keeps tripping out my electric when I turn it on
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Nov 25, 2014
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898184
Points
3964
Disconnect from mains. Remove rear panel and water will probably come out. This water is being flung by the fan onto the heater hence tripping the electric.
cause of water being here is a blockage in the condenser stopping flow into water chamber or possibly but unlikely, failure of the pump
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jun 01, 2009
SOURCE: my aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Candy tumble dryer tripping electricity off. Can anybody help please? is there fault in tumble dryer or the wiring in the apartment ?
The breaker box in the unit may not have the rated breaker for your appliance. Most likely.
Have them check it out.
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
4helpful
Dryer sensor keeps tripping dryer does not heat up
Have you tried replacing the sensor? Would you like a manual?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool condensed tumbler dryer
check ur dryer vent in the back u might have pushed it back too far and kinked the hose ar u might have a buildup of lint in the dryer vent pull the dryer out and take the dryer vent off and run a load of clothes like this if it works look for a lint buildup in the hose or u just had the hose kinked
1helpful
Manual reset keeps tripping. dryer may dry one
May sure your exhaust vent is not blocked or obstructed.
Hotpoint tcl770 condencer tumble dryer, just out of warantee. when turn on and start it keeps tripping the electrics. changed plug fuse etc, tried in various sockets but keeps tripping the system???
internal problem, either heater coil or sensor or motor, you will need to get it checked, but don't plug it in again, as short circuits on high current machines can be dangerous.
4helpful
2answers
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
2helpful
3answers
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
3helpful
Candy cic 60 keeps tripping electric
take cover off fan and see if there is signs of water there. a common cause of tripping is that water is thrown up from the fan onto the element.
get back to me if you find this
4helpful
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
