Engel Freezer 22 Qt. Fridge/Freezer Logo
A
Anonymous Posted on Oct 11, 2014
After a power outage my Samsung SRS580DHLS is displaying and flashing SE? What does this code mean and how do I fix it? Rirht now the control panel only displays SE and does not respond to any presses
Dan Soposky
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 24 Answers
  • Posted on Nov 07, 2014
Dan Soposky
Contributor
Level 1:
New Friend:
Night Owl:
Answers
24
Questions
Helped
10773
Points
52
Your control board is reacting to a surge in power. Unplug the unit for 5 minutes then replug and follow normal starting procedures. If that does not work think about buying a new unit.
What does the blue snow flake mean on the display
If the power /freezer is set the blue snow flake remains lit.
How do use the digital control panel on my Samsung fridge freezer
to turn off for normal operation and power save push and hold power/freezer button for 3 seconds.
2helpful
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
I have a samsung Refigerator RF4287HABP that has an error code SE after a power failure. What should I do.
According to Samsung Customer Support SE stand for Sensor Error... after a power outage... so follow the same procedure as 1e (holding the save energy and lighting button for about 6 to 10 seconds.)
We had a power outage and our ice maker just stopped working. Can it be fixed? thanks
If there was a power surge associated with the outage, maybe not.
Does the display still light up?
3helpful
2answers
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
2helpful
Power outage
I would say that is not a feature, it's a problem. Sounds like the control board has no battery backup of any kind to retain settings in case such an outage occurs. If still under warranty, have it fixed. A refrigerator should be trusted to be left unattended, if this has been this way from new, you should have complained the first time it happened. If they say that it's in the design and all of these do this, perhaps there's a class action waiting to happen.
Please leave comments and check back in, e-mails may not be working after this reply.
3helpful
Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
Top Engel Freezers Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you an Engel Freezer Expert? Answer questions, earn points and help others
