Question about Stihl Ignition Coil, Module Air Gap Guage Tool Bg Br Fr Hl Hs Ht Km
How to replace ignition coil on asthil 029
What is the clearence
usedtotruck2
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Coil should be held on the saw with 2 torx t27 size screws. These will resemble a star. Remove the 2 screws, lift out the coil. The small wire should be attached with a spade connector, slide the spade off with needle nose pliers. Disconnect the spark plug wire from the spark plug, & thread it out of the saw as you remove the coil. Assembly is reverse order of removal. For clearance, loosen coil screws, alike coil away from flywheel
Posted on Nov 27, 2014
Broken wire on stihl 029 saw.
one of the wires will go to a stop switch as that will be the method of shorting out the coil to stop the engine
Jun 03, 2017 | Stihl Garden
How to test coil on 029 still farm boss it has no spark??
Remove the plug and place plug back in plug wire and set where it is close to touching a metal piece and start like you normally would, should see spark coming from plug, if no spark very likely the coil. If coil has omhs listed, disconnect coil and wires and test with ohmmeter
Sep 23, 2015 | Cars & Trucks
029 stihl wont start
Disconnect the stop switch to rule out a problem here, if there is still no spark with the plug out and earthed against the cylinder, then it sounds like a replacment ignition unit is required
Nov 25, 2012 | Stihl Garden
Tappet settings husqvarna 324ld
valve clearance should be 0.10 feeler guage
Flywheel 0.25 feeler guage
Jul 28, 2012 | Husqvarna 324LDX Split Shaft Beam Trimmer...
I am getting a weak (feeble) spark from a new plug and wonder what might cause this? The generator was sitting idle for a long time so the fuel tank and carb were drained, cleaned and flushed, and the...
What you have to do is find out the gap clearence between the flywheel and the pickup coil (induction coil}. A quick and dirty measurement is to align the magnetic portion of the flywheel with the pickup coil. fold a mathbook cover in half and insert it betwenn the magnet and the induction coil. adjust the coil so that it is snug - not tight- against the matchbook cover.This should give you a better clearence for the induction coil to work.
May 10, 2011 | Kitchen Ranges
94 jetta, starter turns engine over, will not start
check timming belt and it it is not turning this is your problem and if so this is zero clearence motor so there is also probley more dammage done to the motor
Mar 03, 2010 | 1994 Volkswagen Jetta
Stihl Ignition Coil, Module Air Gap Guage Tool Bg Br Fr Hl Hs Ht Km Logo
349 people viewed this question
Top Stihl Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
Andrew White
Are you a Stihl Garden Expert? Answer questions, earn points and help others
