Question about ECHO, Inc. PB-251C Handheld Blower
Echo Weed Eater bogs down.
Hello, I have an Echo GT 200R Weed Eater. Recently it started having an issue of bogging down when given gas. It starts up fine but bogs down quickly when throttled. I have had the carb looked at and cleaned. I have cleaned the Exhaust Port and Air Filter. I have not replaced the fuel filter but did inspect it and it shows no sign of dirt or anything else being clogged in it. The weed eater is fairly clean and is only a yr old and has not been used that many times. Do you think I should have the fuel filter replaced anyways? Any suggestions? Thanks!
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Posted on Jul 09, 2009
  • Echo Master
  • 1,631 Answers
Check the following as they are solutions to your the type of problems you reported. Check, then clean or replace:
  • Fuel Filter - Located in the Fuel Tank
  • Spark Arrestor - at muffler
  • Spark Plug
  • Carberutor - May need to have a new rebuild kit
And, then look here for something that is sometimes a problem right out of the box. Manufacturers, have to adjust due to strict emission laws and they are not the same for all areas... "Altitude" has a lot to do with proper 2 cycle engine operation.
Watch this...
Then watch this...
Posted on May 19, 2015
Why does fuel come out of the exhaust when attempting to start it. I t will not start. It [email protected] running, and I put a new spark plug in my weed eater, just to do a little maintenance. It's an Echo GT-200R
over flooded ( crank case full of fuel)
Take the plug out and let it sit for a long time , then pull the cord for a while
dry off the plug
, full throttle , no choke , remove air filter
replace the plug and try starting it
Aug 10, 2018 | Echo Garden
Echo gt 200r
This is a blower, right? What string are you talking about?
Apr 17, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Bought new poulan pro PP125e weed-eater and it has an accelration problem. Manual says may need carburator adjustment. Do you know how to adjust?
new --under warranty -- take it in for a warranty service and adjustment
they will know how to adjust it as well as will have the correct tools for the job
Jul 26, 2017 | Garden
ECHO 2000 WEED EATER I changed the fuel line,
You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
HTH
Good Day.
Oct 29, 2009 | Garden
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Blower shuts off
replace the diagfram in the carb it easy
Aug 21, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
1998 Pontiac Bonneville SE 3.8L Backfires/ Sputters
sounds like the ignition module is going bad.
Aug 04, 2009 | 1998 Pontiac Bonneville
ECHO, Inc. PB-251C Handheld Blower Logo
3,093 people viewed this question
Top Echo Garden Experts
Mike
Nick Olsen
choprboz5
Are you an Echo Garden Expert? Answer questions, earn points and help others
