Was given a ViewSonic VE710b 17" Flap Panel monitor. I am running Win 7 65-bit. Where can I get the proper driver?
SOURCE: Re: Problems with Viewsonic VE710b
Sounds definitely like a failed backlight. Here's a link that tells step-by-step how to replace one: http://www.fonerbooks.com/laptop_5.htm
SOURCE: Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
SOURCE: ViewSonic VE710b 17 inch yellowed photograph look
Hey I had a blue tint on my SVA VR-17S and the monitor VGA cord was what the problem was. But then after that i did auto-adjust and it look good for a second, then went yellow like your is doing. I went through the setting on my there is a Recall adjustment and it resets the factory settings and that fixed my problem.
SOURCE: Remove cover
Did you remove the base from the back? If so, there are two stating slots at the bottom of the screen. A fine blade screwdriver will release these tabs. Once down, the front bezel will pull away but you'll need a flat blade screwdriver (preferably made out of plastic). Slide this screwdriver between the front bezel and the screen frame which is metal. Don't allow the driver to get next to the screen because it will scratch easily. Using the driver you'll be able to pry away the bezel from the rear.
SOURCE: Viewsonic VE710b, the green power light is flashing, no picture
Look for bad caps (bulging/leaking tops) first as shown in my pictures, common problem.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/
Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
