Home Security Logo
A
Anonymous Posted on Oct 10, 2014
<!-- from fixya rte -->How do I secure my safe to the floor/ - Home Security
RSole
Level 3:
Master:
  • Master 697 Answers
  • Posted on Oct 15, 2014
RSole
Master
Level 3:
Master:
Answers
697
Questions
Helped
171141
Points
1886
Drill holes through the bottom, open the door and mark the hole locations on the floor. Attach bolts to the wood or concrete floor, lower the safe over the floor bolts, and fasten nuts with lockwashers onto the bolts inside the safe. When the door is closed no one will be able to undo the nuts. Or use heavy duty lag screws tightened from inside the safe. This will prevent the casual picking up of the safe and slow any thief down.
Moving the safe to a new location
A job better left to the professionals. Or undo the bolts, or if concreted in, hire a jack hammer and dig it out.
https://www.google.com/search?q=Moving+the+safe+to+a+new+location
2answers
I have a floor safe.i have the key but it won’t turn to unlock it
Make sure there no dust or the teeth aren't bent on the key
How to bolt safe to floor
Depends on the safe and the floor. If it is a wood floor and light weight safe, you drill through the safe bottom and then run bolts or screws into the floor through the bottom of the safe. If it is a concrete floor, you need to measure, drill set molly bolt anchors, line up the safe holes with the molly anchors and set the bolts. IF it is a heavy safe, you don't need to worry about it.
Opening my amsec c5 floor safe after losing combination dial
You can just buy a new dial.
https://www.safeandlockstore.com/products/Amsec-Star-Floor-Safe-Removable-Dial-B002000-.html
2answers
I would like to bolt a honeywell safe model 1101 to the floor
Best option i see is drilling holes and using lag bolts into your floor. Depends on the floor you have. Im guessing carpet and wood underneath. Lag bolts would work fine.
6helpful
How do I bolt down Sentry Safe S3310 to the floor?
All of the instructions can also be found at www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
