Roper RT21AKXKQ Top Freezer Refrigerator Logo
A
Anonymous Posted on Oct 10, 2014
How do I stop a water leak coming from underneath the freezer floor into the refrigerator?
Freezer and refrigerator running fine and are cold. Water is dripping inside the fridge from a small rectangular piece of plastic attached to the bottom of the freezer floor, located 3-4 inches from the back wall and 3-4 inches from the right wall inside the fridge
5 Related Answers
A
Anonymous
  • Posted on Sep 25, 2007
SOURCE: Roper refrigerator leaking from pipe
Thanks for your help! I have a tech coming tomorrow so I'll let you know what the problem was.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Aug 13, 2009
SOURCE: RS25AWXEW01 side x side refrigerator has leak at
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Testimonial: "THANKS, THAT SEEMS TO HAVE DONE IT! SHAAN"
Anonymous
  • 121 Answers
  • Posted on Oct 21, 2009
SOURCE: water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Anonymous
  • Posted on Jan 22, 2010
SOURCE: my RT21AKXGW00 has water coming into the
Easy fix...bought a new refrigerator!
viento86
  • 25 Answers
  • Posted on Nov 10, 2010
SOURCE: Water is leaking outside the
THE DRAIN ON THE FREEZER IT'S CLOGGED WHIT ICE U MAY NEED TO DEFROST
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
2answers
JCD2389GT
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
We have got water coming out at the bottom of the freezer of our fridgidair FRC170FF how do i fix it?
1. Your freezer may be not cold enough so water does not freeze.
2. Your freezer may leak so warm air goes into the freezer and keep the temperature higher than freezing temperature.
4helpful
My Bottom pull out freezer is leaking water onto the floor from on top of both feet of the unit. The freezer also has frozen water in the bottom of the unit. I have removed the frozen water in hopes that...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
1helpful
Hey i have a model TBF17PC top freezer and its leaking water on the floor.. opposite to the water trey. also water builds up underneath the vegetable trey
Leo Ponder
imufo2
Water leaking inside a top mount frigidaire. Freezer is fine. Food is cold. Not sure what to do.
Leo Ponder
imufo2
My Kenmore side by side (cannot locate the model # anywhere) is leaking water underneath the left side of the freezer door. When I look in the freezer there is water frozen in the bottom. I have looked...
Leo Ponder
imufo2
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Top Roper Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
