I got a cassette tape stuck in my Aiwa compact disc stereo system and broke the door on one side getting the cassette out. There seems to be a piece broken on one side. Door will not stay closed. I need a repair shop in my location that is able to fix it. Richardson, TX 75080
Google AIWA service centers or go to the AIWA website for help through Customer Service. Good luck!
PS Best Buy Geek Squad may offer repair options.
Posted on Jan 14, 2018
SOURCE: cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Posted on Nov 03, 2005
SOURCE: cassette doors
Bent or broken door latching part. Take in for service
Posted on May 07, 2008
SOURCE: aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Posted on Apr 20, 2009
SOURCE: Cassete deck will not work, I put a tape in deck 2
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Posted on Jun 05, 2009
SOURCE: All I want is to download a free manual for a
Have you tried the Aiwa website? Makers often put user manuals on for free!
Posted on Feb 19, 2010
Oct 21, 2015 | Aiwa Audio Players & Recorders
Nov 03, 2012 | Audio Players & Recorders
May 28, 2012 | Aiwa Audio Players & Recorders
Apr 27, 2012 | Aiwa Audio Players & Recorders
Feb 17, 2010 | Audio Players & Recorders
May 15, 2009 | Aiwa XC-RW700 2-Disc CD Recorder
Feb 20, 2009 | Aiwa Audio Players & Recorders
Oct 22, 2008 | Audio Players & Recorders
Dec 25, 2007 | Aiwa Audio Players & Recorders
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
325 people viewed this question
