Question about Panasonic DMREZ485VK DVD/VCR Player
I am having audio issues on my recorder. The other day the recording and output volume was fine. Today the sound is very low. I have not changed any settings on the recorder or the television. I ha
I am having audio issues on my recorder. The other day the recording and output volume was fine. Today the sound is very low. I have not changed any settings on the recorder or the television. I have the following in the Set-up menu: Dynamic Range Compression - On Multi-Channel TV Sound (Analog) - Main Multi-Channel TV Sound (Digital) - English Digital Audio Output: a) PCM Down Coversion - Off b) Dolby Digital - Bitstream c) DTS - Bitstream Select Audio Channel For DV Input - Stereo 1
  • Panasonic Master
  • 924 Answers
You failed to mention what kind of recorder this is.
Posted on Nov 08, 2014
4 Suggested Answers
6ya staff
SOURCE:
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Posted on Dec 16, 2008
Anonymous
SOURCE: We have a VHS/DVD recorder connected between a
We realized that we needed to have the converter box on and we had been turning it off. We left it on and did succeed at recording a show last evening.
Posted on Dec 31, 2009
coralsoft
  • 6 Answers
SOURCE: My Panasonic DMR-EH55 recorder produces no sound
Did you get anywhere with this? I have a similar problem with a DVD/PVR from Woxter. I've tried different cables and changed many of the settings without luck. I've seen a couple of posts which suggest changing country and sound settings (to PCM), so I'll check them out before I call in a repairman to check out the circuitry around the sound output.
Posted on Jul 01, 2011
Tascam 488 Tape Recorder
Have you tried playing the tape in another device? Adjusting the recording volume if that is an option? Look for the user manual pdf online and also try a brand new or different brand tape to ensure that is not the problem.
Nov 16, 2013 | Tascam Audio Players & Recorders
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
I record but the sound is very very low.
If you are recording from a line-out coming from a headphone output from the TV try increasing the TV volume. (and check the signal is strong by testing with headphones).
If you need to still increase the recorded volume... open the Volume control mixer; open the properties for Recording; select an Advanced option and then Microphone boost
Jul 09, 2009 | Pinnacle Dazzle DVD Recorder
Very low output volume from Presonus Firebox recordings
i do'nt know the name of the sound driver installed in my PC
Jun 30, 2009 | PreSonus Firebox 6x10 External Sound...
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
Audio Recording
There are many streaming audio recorder. But I prefer Wondershare Streaming Audio Recorder,It can download streaming video offline,you can download aol radio,myspace music and so on.
http://www.download-streaming-video.com/streaming-audio-recoder/#137
You can have a try.
Mar 28, 2008 | Dell Dimension 3000 PC Desktop
M-Audio Pre USB
I guess your output is leaking and you are recording it again to the track.
Try recording with lower output volume. :)
Mar 16, 2008 | M-Audio Mobilepre USB Bus-Powered Preamp...
Panasonic DMREZ485VK DVD/VCR Player Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
