Want to know what causes that error , Machine error 6A
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
SOURCE: WHEN I TURN ON MY
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
SOURCE: reset fuser
Hello -
This is a good question.,. and you have got me stumped! What I would do is contact the manufacturer's tech support line, they would be far better suited to provide a more accurate answer...
Best regards,
Ck
