Yaesu vx 300 vhf two way radio
SOURCE: YAESU VHF AM Transceiver VXA-100 battery doesn't
If this charger is one that plugs into the radio then you will have to take a volt meter and check the voltage on the plug. It should be close or slightly higher in voltage than the label on the power supply.
It most likely be that the transformer or the contacts in the plug are bad.
You could try and turn on the radio with the battery on and see if the radio comes on.
SOURCE: is there any possible repeater
Your question does not make sense.
Yaesu is the amateur radio manufacturer for the Vertex Standard company. Motorola only makes commercial radio equipment. Both can be programmed or configured to use repeaters.
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
