Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Hi, i have error code c2555 on my konica minolta bizhub c250. printer continuosly tries to supply toner to the IU, so wont print.have swapped toners and IU but did not fix problem. suspect it is a damaged stepping motor because i can hear a weird noise coming from one of the motors, and i smelt a burning odour moments before my printer stopped printing. could this be some circuit board? could someone please help? would really appreciate any help. ([email protected]) thank you
Posted by why do you want my... on
  • 1 more comment
  • can you please confirm how to access the i/o check. many thanks!
  • hi there, 1st of all, THANKS!
    can you just plz confirm how do i access the i/o check. (...stop00stop01?)
    Rgds
  • FiftyJeans Jan 02, 2012
    Make sure you present the reset key at the back of the machine where the dashboard is
Konica Minolta Error Codes and Solutions
  • 210 Answers
Most likely it is your toner hopper drive broken. It is a common problem on these machines. Just replace this part.
Posted on Aug 23, 2009
Anonymous
    Problem Solver:
  • 17 Answers
Go in i/o check and u can check motors
Posted on Jul 07, 2009
Error c2555 in konica minolta c250
I presume that you want to know what this code means rather than just telling us that you have it!! Search online for "error code c2555 Konica Minolta". Try the fourth hit and onwards.
Jul 11, 2015 | Konica Minolta BizHub C252
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica error code c-2553
replace the magenta image unit
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 16, 2014 | Konica Minolta Bizhub C250 Magenta Toner...
Biz Hub C250 is dumping too much yellow toner, what are some possible reasons/solutions?
Bad cleaning blade in the drum (Image Unit). Because toner goes in the image in the front not the middle or rear.
Mar 08, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c250 error C-2AO3
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
Oct 04, 2012 | Konica Minolta Minolta Konica Bizhub C250...
Konica bizhub 250 error c255c
there is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
Oct 08, 2010 | Konica Minolta Bizhub c203 Copier
Konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
May 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhubc250
C2555 means yellow TCR sensor problem.
solution, make sure the yellow toner is not empty.
try to pull out the yellow IU then shake it, and put it back.
Jul 10, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
2,305 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
