SOURCE: Scott ZXP8 Eclipse cd mini hifi system
Was the fuse Blown?? check with an ohm meteracross the two prongs that you plug into the wall of course you gotta unplug it for this. It should read around 4 to 10 ohms depending on the type of power transformer is in the unit.. If it reads open then theres a fuse open or a bad power transformer. If its not open check the power supply for the proper voltage from the diagram. Good luck
SOURCE: SHARP BA1700
Dear steve37,
Please switch off the system from the wall socket. Remove the speaker wires from the rear side of the system. power on the system if it works ,the speakers or the wires are defective.
ramesh22
