Question about Frigidaire 31 in. FEC30S7E Electric Cooktop
Frigidaire electric cooktop locked
Cooktop locked
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, friend!
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
Posted on Oct 13, 2014
Our Frigidaire Gallery induction cooktop is 'locked'. How to unlock?
Press and hold the keypad with the padlock icon until you hear a beep. This should be about 3 seconds. This will toggle the lock on and off. I used the documentation for the Frigidaire FGIC3067MB to check this. On this model, the lock keypad is to the left of the Keep Warm keypad. https://www.frigidaire.com/Kitchen-Appliances/Cooktops/Induction-Cooktops/FGIC3067MB/ . The manual is here: http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205604en.pdf . The control panel is shown on page 5 and the lock function is shown on pages 6 and 9.
I hope this helps.
Feb 28, 2018 | Frigidaire Cooktops
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
Frigidaire model fef336fmf troubleshooting
Hi jontherun5 - What is the problem your electric range is having or concern on the product?
Sep 20, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
How much will it cost to replace a broken Electric Ceramic Cooktop for a Frigidaire ModelFEFB79GSA?
the elect cok top mod fec30s7e ( main top in blk/ steel / or glass = 199.49 + shipping ) the mod fefb79gsa is a white top 208.22 + shipping / labor is on both about 100.00 = tax .. mm
Dec 03, 2009 | Frigidaire 31 in. FEC30S7E Electric...
I need to know the ampere raitng or the wattage so I can size the electrical feeder to the cooktop
The installation guide, on page 3, says this cooktop can use up to 9700 watts. It also says to use #8AWG wire and a 40 amp 240 volt breaker. You can download the installation guide here:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318201427revA.pdf
Feb 19, 2009 | Frigidaire PLEC36S9EC Stainless Steel...
Smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Jul 21, 2008 | Frigidaire 31 in. GLEC30S8 Electric...
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire 31 in. FEC30S7E Electric Cooktop Logo
129 people viewed this question
Top Frigidaire Cooktops Experts
gbob59
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
