Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
SOURCE: Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
SOURCE: I have a Frigidaire Crown Front loader washer,
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
SOURCE: I have Frigidaire Affinity washer that beeps and blinks "dr"
Actually don't buy a new door mechanism yet. There is a metal ring that holds the rubber tub to the rest of the washing machine. It has a spring at the bottom of that ring. Pull it down and you will be able to get the ring off. Carefully peel back the rubber tub on the right had side near the door latch. Reach in side and unplug the bottom connector for a few seconds and plug back up. (Do this all with the power on). Then put the rubber tub back around the frame and put the metal ring back on. This should solve your problem. I had the same issue not too long ago.
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
