Sony Mhc-gx9000 Compact Stereo With 3-cd Changer Logo
J
Jane Davis Posted on Oct 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have two rock outside speakers that came with a short wire attached to it. I am wanting to connect to my stereo system (not a fancy one) along with the speakers that are already connected to it.
I have two rock outside speakers that came with a short wire attached to it. I am wanting to connect to my stereo system (not a fancy one) along with the speakers that are already connected to it. Is there an adapter I can get to let me hook 2 speakers to each side of stereo instead of the one speaker that came with it.
Steve K
Level 3:
Genius:
  • Sony Master 1,054 Answers
  • Posted on Oct 10, 2014
Steve K
Sony Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
573875
Points
2865
You would need to hook it up to a speaker switch box. This will match the impedence so that you don't blow the amp by hooking up more than one speaker
5 Related Answers
Anonymous
  • 682 Answers
  • Posted on Aug 02, 2008
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Anonymous
  • 863 Answers
  • Posted on Nov 01, 2009
SOURCE: Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
Anonymous
  • 30 Answers
  • Posted on Dec 17, 2009
SOURCE: Sony HT 6500 receiver...center speaker jack
try to spray contact cleaner into the speaker port itself.. Powered off of course.. let it dry and try again.. this will clean any connectivity issues due to bad contacts.. as far as replacing jacks.. try the suspected "bad" speaker and wiring in another port.. if it works then the speaker and wiring is good and you have to check actual jack in which you were asking and back to auto amplifier circuit or transistors.
Anonymous
  • 458 Answers
  • Posted on May 11, 2010
SOURCE: there is message PROTECT on display.how to solve it?thanks
need replaced power out ic and transistor....
Anonymous
  • 8546 Answers
  • Posted on May 21, 2010
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
It`s showing overload
There are a number of causes....but most of the time something in he speaker section is shorted. Turn off the stereo...Remove all connected speakers from the back...turn it back on. Is the error message still there? If so its internal...if not turn off again and attach one speaker at a time, turning the stereo off to add each speaker. until error. You could have a shorted speaker or wire or too many speakers.
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
How do I wire the system
You would require an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire.
The complete installation process is as follows
#1
Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
#2
Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
#3
Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
#4
Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
#5
Put the fuse in the fuse holder.
#6
Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
#7
On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
#8
In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
#9
Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
#10
Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
#11
If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
#12
Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
#13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. You are all done!
Hope this helps
Thanks
I have 2 8 ohm stereo speakers, old school nothing fancy, I want to put a much longer and heavier wire on them. How do I do this. I do not want to spice into the existing wire.
Hi I am vortash , The easiest way would be to fit a couple of speaker spring connectors onto the back of the speakers , you've seen the type a small hole and you lift the clip insert the wire and the clip springs down holding the wire secure available from any Radioshack or Maplins usually coloured red & black .. then you can fit any cable you like to them and even extend them at a later date if you wish ?. Regards vortash
Need wiring diagram
Step 1 Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system.
Step 2 Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires.
Step 3 Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers.
Step 4 Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation.
Step 5 Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them.
Preparing for the installation
Step 1 Be properly prepared. This is extremely important since you do not want to realize you're missing something in the middle of the installation.
Step 2 Purchase the following: A car stereo wire harness which connects the existing wiring for your old head unit to your new one (this will be specific to BOTH the model and year of your car AND to the make of your new head unit); an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
Step 3 Obtain a guide to removing the dash, doors panels (or whatever compartment the speakers are in), and floor molding of your car. You may be able to find a guide for this online. If not, you can get a repair manual for your car at most automotive stores and online).
Step 4 Gather the following tools: Screwdrivers to fit the job, pliers, wire cutters, wire strippers, a utility knife, sand paper or a file, electrical tape, a 9-volt battery, and any other tools that the instructions for installing the head unit and your car guides specify.
Installation Process
Step 1 Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
Step 2 Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Step 3 Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
Step 4 Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
Step 5 Put the fuse in the fuse holder.
Step 6 Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
Step 7 On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
Step 8 In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
Step 9 Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
Step 10 Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
Step 11 If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
Step 12 Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
Step 13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. That's all!
Good luck.
15helpful
2answers
My JVC mx-gc5 stereo says protect and then shuts off
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
1helpful
My main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
18helpful
3answers
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
