1 – Is the NO SIGNAL issue happening on just one TV? CORRECT INPUT or SOURCE If it is just one TV that is showing the NO SIGNAL… -Be sure your TV is on the correct source or input as your CABLE or SAT BOX. -Press the TV button on TV remote control to turn your TV ON. -Press the INPUT button on your TV remote control. -Cycle through all the inputs on your TV. -Do this until you are on the INPUT your CABLE or SAT BOX is plugged into. -You should then see the CABLE or SAT programming show on your TV. HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on. If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL… CABLE OR SAT BOX NEEDS RESET -Remove or unplug the power cable from the Cable TV or SAT set top box. -Keep it unplugged for 2 to 3 minutes. -Plug the power cable back into your Cable or SAT set top box. -Give it some time for the Cable or SAT box to power up, get the signal, and initialize. If you still see NO SIGNAL on your TV screen, see the next step below…
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL… UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX -Remove the HDMI cable or other cables from your Cable TV or SAT set top box. -Keep the cable unplugged for 2 to 3 minutes. -Plug the HDMI cable or other cables back in. -Give it some time for the Cable or SAT box to get the signal and initialize. HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen… BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY -Be sure to check the ones where the CABLE or SAT come into your home. -Be sure ALL Ethernet and Coax cables are secure. -Call your CABLE or SAT provider to see if there is an outage. -Realign your Dish if you have SATELLITE.
Consult the manual for troubleshooting tips. Other than that you may want to get a new blender as repairing it would be more costly than the unit itself. Download Cuisinart CBT 500 Manual
since you have a dish reciever you could try connecting the dish box to the television with the AV cables.. (yellow, white and red cables) to the television. once that is done press the source button on the remote until it displays composite then you will have the picture from the sat box. Try it like this to see if it still loosing the signal..
Also you could try is turn off the sat box then back on and see if that fixes that problem if it does could be something wrong with the sat box.. also test a dvd player to see how that reacts.. if that plays good and you connect the sat box on that same connection then the sat box could be having some issues.
