Craftsman 190cc* 22" Front Drive Self-Propelled EZ Lawn Mower 50 Logo
A
Anonymous Posted on Oct 09, 2014
Craftsman 6.75 eager1 seeps oil at lower part of motor
Seeps oil where motor bolts on to body
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Craftsman Master 1,917 Answers
  • Posted on Oct 10, 2014
charles beach
Craftsman Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570462
Points
3010
Have to replace sump gasket
1helpful
What is the easiest way to replace the oil pan on a 2003 Suzuki XL7 Limite 4WD - Front of the pan (lower) was dented in the past and now the oil is slowly seeping through.
THE SHOP MANUAL COVERS THIS. ON ALL CARS.
IN ALL OR MOST CASES THE PAN MUST CLEAR THE OIL PUMP SUCKTION PICKUP TUBE AND STRAINER.
a problem as is 4wd cars. all. worse
country ,vin or engine told and is a pure engine /body question
I did it on my 4.0L jeep long ago, listed as engine pull only, and only did jackup.
mounts off. real tricky that.
I will post for USA car only, from the BOOK
XL-7 see that dash?
2.5 or 2.7L engine h25,h27 , i had GV 2.7L 2004
quote
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Oil dipstick tube
    • Front wheels
    • Front skidplate, if equipped
    • Steering gear
    • Front differential, if equipped, 4wd
    • Lower oil pan
    • Oil pickup tube bracket
    • Radiator outlet pipe
    • Upper oil pan and oil pickup tube
installed
  1. Install a new O-ring to the lower crankcase.
  2. Apply a bead of silicone sealant to the upper oil pan flange.
  3. Install or connect the following:
    • New oil pump pickup tube O-ring seals
    • Upper oil pan and oil pump pickup tube and tighten the fasteners as shown
    • Lower oil pan. Tighten the bolts to 97 inch lbs. (11 Nm).
    • Steering gear
    • Front wheels
    • Oil dipstick tube
  4. Fill the crankcase to the correct level.
How change oil for model eager1 944.364100
remove plug from bottom drian oil then reinstall add oil
How change oil for model eager1 944.364100 3.5 hp
usually you take dipstick out and turn them on there sides to drain the oil
2answers
Where is trans filter located
The follwoing is from the GM Shop Technical Manual.
Changing the filter requires removing the transaxle oil pan and gasket,
  • Raise vehicle and suitably support.
  • Loosen oil pan bolts and drain fluid,
  • Remove oil pan attaching bolts.
  • Remove pan pan and gasket.
  • Remove the oiil filter using a long screwdriver pry filter neck out of the seal.
  • Check oil filter seal for damage or wear. If needed, remove and replace
Install or connect
  • install new oil filter and/or seal.
  • install the old pan gasket since it can be reused, unless sealing ribs are damaged. If damaged, use new gasket.
  • Install the oil pan and attaching bolts.
  • Tighten pan bolts to 13 lb. ft,
  • Lower vehicle.
  • Refill transxle to proper level with DEXRON III or DEXRON-IIE fluid.
  • Checkoil pan gasket for leaks,
1helpful
How to remove and install starter motor on 2000 malibu location of mounting bolts
REMOVAL & INSTALLATION 2.4L Engine
  1. Disconnect the negative battery cable at the battery.
  2. Detach the air inlet duct from the throttle body.
  3. Position a drain pan under the oil filter, then remove the oil filter.
  4. Remove the top starter bolt.
  5. Raise and safely support the vehicle.
  6. Remove the lower starter retaining bolt.
  7. If necessary, position the engine wiring harness aside.
  8. Position the starter to enable access to the solenoid wiring, then detach the wiring.
  9. Remove the starter from the vehicle. To install:
  10. Raise the starter to the vehicle, then attach the wiring.
  11. Position the starter, then secure using the lower starter bolt. Tighten to 66 ft. lbs. (90 Nm). Fig. 1: When installing the starter on the 2.4L engine, tighten the mounting bolts to 66 ft. lbs. (90 Nm) 87952040.gif
  12. If moved, reposition the engine wiring harness.
  13. Attach the solenoid electrical connectors.
  14. Carefully lower the vehicle.
  15. Install the top starter bolt, then tighten to 66 ft. lbs. (90 Nm).
  16. Replace the oil filter.
  17. Fasten the air inlet duct to the throttle body.
  18. Connect the negative battery cable.
  19. Check the oil level and add if necessary.
  20. Start the engine, recheck the oil level and add if necessary.
3.1L Engine
  1. Disconnect the negative battery cable.
  2. Raise and safely support the front of the vehicle securely on jackstands.
  3. Remove the lower closeout panel.
  4. Remove the electrical leads. Fig. 2: Two electrical leads connect to the starter solenoid. The larger one has battery power as long as the battery is connected. The smaller one only has power when the key is turned to START 93202p09.jpg
  5. Remove the starter motor to engine bolts, then remove the starter from the vehicle. To install:
  6. Install the starter. Position one engine-to-starter bolt in the lower bolt hole, then finger-start the bolt.
  7. Connect the electrical leads to the starter. Tighten the cable to the solenoid to 106 inch lbs. (12 Nm).
  8. Install the starter-to-engine bolts and tighten to 37 ft. lbs. (50 Nm)
  9. Install the lower closeout panel.
  10. Lower the vehicle.
  11. Connect the negative battery cable.
3helpful
2answers
Need a motor diagram torch settings and overhaul
Hi,if you go to autozone.com and sign up for my zone(it's free).Thay have a on line free repair manual,it has everything needed to rebuild the top end of his engine and more.Hope this helps you.If it does please rate it. Thank You for using fixya.....iluv2fish.......Ray.....
Mower is oozing oil from bottom of fill tube which has come loose.How do i get it situated back tightly where it belongs? Craftsman Eager1 6.75
Check to see if a small bolt is missing. thats usualy all there is holding them in place. I had that problem before.
Apr 21, 2010 • Garden
I have a carftsman walk behing mower with an eager1 egine
did you turn the mower upside down then the oil filled up the oil filter take off the filter then it should start it has to breath it takes mor air then fuel to make a engine run
2helpful
2answers
6.75 Craftsman Eager1 Lawnmower, My son had this mower given to him,after cleaning the carb,plug,air cleaner etc. I noticed a black rubber tube entering the top of the motor at the back, upon starting the...
Go to parts www.searspartdirect.com and put in the model # and it will display all the parts that are supposed to be on the mower. Whatever you are missing just order from them.
May 16, 2009 • Garden
1helpful
Got a craftsman eager1 self propelled lawn mower model 917 374411
gas flows out of red tube in to air filter housing.is the primer the problem?
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
