Broken platen knob on Smith Corona SL 575. Cant
Broken platen knob on Smith Corona SL 575. Cant find replacement! Help!
Dick O Reilly
  • 3,594 Answers
Google smith corona dunkirk ny if they don't have it you probably won't find one.
DickyO
Posted on Oct 13, 2014
1 Related Answer
bernieq
  • 6 Answers
SOURCE: I need a user manual for smith corona SD 680 Word processing
http://www.manualfox.com/
Posted on Dec 11, 2008
How would I test the humidity sensor in my LGDLE2514W? I've already replaced one metal strip out of two from that sensor. It did not help. Thank you for your help!
If the sensor was replaced but not help, the issue may be from control board. You do not say why you did replace a sensor, this part is hardly to be faulty.
Sep 07, 2013 | LG DLE2514 Electric Dryer
Starter relay location on 1999 durango 4x4
Its located in the under hood engine compartment fuse box.
There will be three same relays.One for fuel pump and other for horn and bit bigger one for starter controlling.
For more help regarding starter
CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE RUNS.============
For your help there are few relatively help links showing how to remove and install starter with proper instructions:-----
These help links will help.
Click the link below:-----
How to test starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test cars starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
How to replace Starter on Infiniti Q45?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
2006 GM Montana: How to replace Starter Solenoid?
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
Saturn SL2: How to replace Starter Motor?
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
Oldsmobile starter solenoid replacement procedure?...
How to replace Oldsmobile starter moor?
Oldsmobile starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These details will help.
Thanks.
Nov 28, 2012 | 1999 Dodge Durango
Cant remove my starter from 1997 fordareostar
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html ----------- How to replace starter in car?
How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
Thanks.
Nov 26, 2012 | Cars & Trucks
How 2 wire a stater on a 2000 chevy cavalier
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html----------- How to replace starter in car? http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
-----------How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
---------- 2006 GM Montana: How to replace Starter Solenoid? http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
-----Saturn SL2: How to replace Starter Motor?
------------These details will help.Thanks.
Nov 23, 2012 | Cars & Trucks
How to install evo 5 tail lights
check see tail light lens has 4 screws holding it in place.if so remove 4 screws then remove rear tail light lens then replace tail light bulbs.if you have trouble replacing tail light bulbs the auto parts store sales person will help you free of charge and help you replace bulbs.i have seen auto parts stores sales person help people replace batteries,windshield wiper blades and light bulbs in vechicle if you have trouble fixin it your self.
Feb 06, 2012 | 1998 Mitsubishi Lancer
How do i retrieve my contact on MTN backup
please i have just replaced my number and i want to restore my contacts this is the number 0782321035
Oct 03, 2011 | RIM BlackBerry Storm2 9550 Smartphone
Motherboard repair
First Replace BIOS battery
Replace main filters (Capacitors)
Aug 23, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
93 people viewed this question
Ekse
Marvin
Marvin
