Hi Shane kelly, I would look at whether freezer is defrosting or is ice building up behind the fridge panel at the back and then freezing your fridge compartment.
It takes like 2 days for the ice to melt if this is the case.
Then freezer will work for a while and then when defrost is missed it builds up the ice again.
If this is what is causing problem it could be a transducer fault in the freezer that detect ice or a timer fault in the defrost circuitry.
Andrew writes
Also check the evaporator circulating fan inside the freezer. The defrost timer and ice build up is also my other suggestion. The evaporator becomes a solid block of ice and doesn't pass air.
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
I think it is your thermostat this controls the motor theirs a top 1 & a bottom 1 they both control the motor 1 4 freezing the other chilling because u say they are both not working it is also posable that ur f/frezer may need re charging
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
