A CD is stuck in the slot of my bose wave music system It won't eject the CD. Just clicks.
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
SOURCE: What's your problem?Bose wave system cd doesnot eject
Contact the nearest authorised service center for Bose. CD loading mechanism has been struck. You have to open it. It is a skilled work.
SOURCE: cd stuck
HI,
It is jammed and it will not come out of it. You have to open the cover
and manually eject the CD from it. There is no other way you can take
it out.
The best solution is to get it serviced.I hope it is still under warranty.
Goodluck..
SOURCE: My grandma has a Wave
First you'll need to take the cover off the system. Once inside you should be able to take the cover off the CD Tray and remove the CDs by hand.
SOURCE: CD not playing with bose wave system but same cd
The cd assembly is the issue, over a period of time the laser pickup becomes weaker until it can no longer read the disc, one possible solution is to buy a disc cleaning kit and follow instructions in an effort to recover the assembly. If that fails the only option is contact Bose for pricing since they are the only authorized service centre that work on their own products.
