Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB Logo
A
Anonymous Posted on Oct 09, 2014
How can i solve the error " Replace the toner "
Suraj Paneru
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 13, 2015
Suraj Paneru
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1697
Points
10
Go to -menu-machine info-reset drum (press ok button for 10 second)and press ok- no display- then press + 10 times and ok
darinthal
Level 2:
Novelist:
  • Brother Expert 181 Answers
  • Posted on Oct 10, 2014
darinthal
Brother Expert
Level 2:
Novelist:
Answers
181
Questions
Helped
51566
Points
361
Replace the toner with one bought either from a Brother Stockist or a remanufacturer of toner cartridges.
3answers
HOW CAN I CLEAR CODE ERROR F2 40 ON SHARP MX-M453N PHOTOCOPIER?
That is a miss reading of the toner density sensor. Which is located in the developer unit Replace the sensor or dv unit. Also check the connection of the unit to the copier and the harness from the sensor to the dv unit.
Konika c 552 error code is 2a21 New release filur. How to solve
Here you go!
Konica Minolta bizhub C3350 Error Codes
Code
2A21
Description
Toner cartridge/C new release failure
The status with the new cartridge is not cleared after the new toner cartridge is set.
Causes
ā€¢ Toner cartridge/C,M,Y,K ā€¢ Printer control board (PRCB)
Remedy
1 Check the connector between toner cartridge-relay CN79-EXCB CN4 for proper connection and correct as necessary. - - 2 Clean the connection between the toner cartridge and the machine if dirty. - - 3 Reinstall the toner cartridge 4 Check the harness for proper connection and correct as necessary. - - 5 Check the connector between EXCB CN2-PRCB CN11 for proper connection and correct as necessary. - - 6 Replace the toner cartridge - - 7 Replace PRCB
Anthony
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
2answers
How to solve error code c-2553
The toner abnormality you have to clean toner hopar and clean senser and again OFF and ON
9helpful
2answers
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
1helpful
Corona cleaning does not solve error message
You will need to replace the drum unit on the printer.
Displayed error
sol:
1:you have to replace the drum unit.
or
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
Norman Weimar
Norman Weimar
k24674
