HP DeskJet 5150 InkJet Printer Logo
Question about HP DeskJet 5150 InkJet Printer
My HP 5150 Deskjet printer is not printing, I have done the Tap 43 test and all seems fine, but as soon as I try print the on button flashes
5 Related Answers
Anonymous
  • 238 Answers
SOURCE: Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Posted on Dec 16, 2007
Anonymous
  • 638 Answers
SOURCE: H.P.Deskjet 5150 printer
TRY CLEANING THE SURFACE WITH MOIST CLOTH THAT CONNECTS WITH UR COLUR CARTRIDGE CIRCUIT.WISH U SUCCESS
Posted on Jun 03, 2008
Anonymous
SOURCE: HP deskjet 5550 printer not printing.
hi
my printer is not working
Posted on Nov 21, 2008
Inkworks
Orn Wilson
  • 104 Answers
SOURCE: my hp deskjet 5150 will not stop printing
You say test page....what is on this test page? Could be an alignment page.
Inkworks
866-381-0541
Anonymous
SOURCE: HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Posted on May 06, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: [email protected]
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
I can print from Word on my HP 5150, but it prints multiples
sounds like a problem with the printer software, try uninstalling & then re-install the printer driver
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Hp deskjet 5150 paper jam
u have to need to do change the printer roller
HP Deskjet 5150 won't print black
ya hi, the nozzels must have got dried up and choked, put a few drops of hydrogen peraoxide on the nozzel for some time and then clean it, this will free the pores in the nozzel, be careful with the chemical, or take some proffessional assistance.. let me know
HP 5150 will not print from programs MS Works and MS Word.
ayant egere le CD d'installation de mon imprimante hp desjet 5150, je ne parviens pas a installer mon imprimante. ou puis-je touve le driver, le lien sur le site hp.
merci par avance
HP DskJet 5150 will not print black
re-install the print drivers. if it still doesn't print problem lies in the bubblejet power supply - not user fixable
Ben Johnson
Marvin
Marvin
