Refrigerators Logo
A
Anonymous Posted on Oct 09, 2014
Looking for owners Manuel for a GE REFRIGERATOR MODEL # GSS25QGTA WW
Need Manuel ice maker not working, also very loud at times almost sounds like fan is hitting against some plastic.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • GE Master 102,366 Answers
  • Posted on Oct 09, 2014
GE Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428182
Points
622693
5 Related Answers
Anonymous
  • 161 Answers
  • Posted on Jul 03, 2008
SOURCE: GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Anonymous
  • 291 Answers
  • Posted on Dec 04, 2008
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
Anonymous
  • 71 Answers
  • Posted on Dec 24, 2008
SOURCE: Hello, I have a GE
more info ie no crushed , no ice, no water?
Anonymous
  • Posted on Aug 15, 2009
SOURCE: GE Refrigerator, model PSS26MGPBBB, stop
PROBLEM IS ASSOCIATED WITH THE TEMP SENSOR INSIDE ICE MAKER. I HAVE TRIED TO FIND THE PART, BUT WITH NO LUCK. IT LOOKS LIKE WE WILL HAVE TO PURCHASE A NEW ICE MAKER.
geapptech
  • 157 Answers
  • Posted on Feb 28, 2010
SOURCE: GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
We have a GE gss25qgta ww and the ice cubes won't dispense but the water is working. There also seems to be frost building up on the coil in the ice tray. There is also occasional noise - sometimes quite...
Here's what I found for you.....
go to this site....
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gss25qgtaww-repair/gss25qgtaww-ice-maker-wont-dispense-ice.html
the part is 32 bucks and if you are able to follow the video repair you can do it yourself. two things needed a putty knife and a phillips screwdriver. Probably a 45 min fix.
they have a 800# to confirm DIY repair. and insure the part is a exact replacement, or just to confirm the issue.
repair trip charge and labor could easily exceed the part $ x 3 to 4 times.
Hope this helps
Cheers
1helpful
2answers
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
GE refrigerator/model GSS201EPH WW. Water dispenser works fine, ice dispenser does not work
there is a pump which pushes water up to ice maker, it usually quits, causes the prob. 90% time
I have a ge sisde by side model#gss25rgma ww. the fridge/freezer is working good, but now not making ice, it has started to make a really loud humming type sound if the doors are left open to long than...
Sounds like a evaporator fan motor problem. However remove rear panel and if slight frost on top of evaporator replace motor if not post back or call professional
GSS201EPH WW.... Freezer is making a very loud noise. It sounds like a fan hitting. Everything works
Check to see if the condenser fan in the rear of the fridge towards the bottom isn't hitting anything. If its inside the fridge it might be ice built up around the evaporator fan.
Ice Maker
Put less water into the ice tray.
3answers
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Top Refrigerators Experts
vince
Johnny 1000
