Water is leaking from underneath refrigerator
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
SOURCE: water leaking
I think this will help..
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
SOURCE: kenmore side by side - water dispenser leaks from time to time.
The problem is most likely at the water inlet valve located at the floor at the back of the refrigerator. These valves have a seal that should close off after use but sometimes stick or get a foreign object in the seat. It is intermittent causing only an occasional leak. Sadly, there is no service to the valve and you can only replace it. Good luck, AJ
SOURCE: Kenmore Elite - bottom Freezer - water leak from refrigerator
Found this solution on another site. http://davesgarden.com/community/forums/p.php?pid=6759829
