Question about FUJIFILM Cameras
Fujifilm Finepix AX Flash Is Not Working/Turning On
I was taking pictures with my camera today, when the flash just stopped working, even when I put the flash on forced. It just takes a plain picture. I even reset the settings, and still no dice.
Peter Schr?der
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 241 Answers
If your camera is in "silent mode" the flash will not work. Press and hold the Disp/back button for a few seconds and the camera will toggle between "silent mode" and "normal mode"
Posted on Oct 10, 2014
5 Related Answers
early1234
earl norman llanera
  • 871 Answers
SOURCE: sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Posted on Jan 22, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: flash does not work
Ok,
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
Posted on Dec 27, 2008
Anonymous
  • 20 Answers
SOURCE: Fujifilm FinePix 3800 flash will not work
Normally when the flash stops working it is because the capacitor the camera uses to store the flash power ( that is what charges..not the bulb) burns out. This is a very difficult repair and should only be completed by a camera technician.
If the repair is over 10 dollars I would suggest a new camera.
Posted on Jan 28, 2009
Anonymous
SOURCE: My FINEPIX s1000fd fujifilm camera
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Posted on Apr 01, 2009
Anonymous
SOURCE: Model DSC-S730 Camera flash is not working
how to reset camera
Posted on Apr 03, 2009
My fujifilm instax mini 7s flash stopped working. The photo's turn out black and when i take a picture the flash doesn't turn on. What do I do and if I need to replace the flash, How much will it cost
My camera flash isnt working i barley used it. The pictures are coming out black and I'm trying to fix it myself. The flash isnt coming on at all.
Dec 30, 2017 | FUJIFILM Cameras
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
Will not take a picture with flash
this URL is for the manual for your camera http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_av100_manual_01.pdf Page 28 explains how to toggle the flash on and off in different modes. It is easy and the explanation is short and clear. It is preferable to use a flash for fill light almost all the time so these modes are really great. However if you are in a low light setting you don't want the flash or you will get the 'snapshot' flash look. Try holding camera very steady and keeping the subject from moving too much and shoot without the flash. Once you get the hang of turning the flash on and off you won't hardly even need to look to do it....
Jan 06, 2014 | FUJIFILM FinePix AV100 Digital Camera
How do I turn the sound off on my fujifilm finepix z70 without turning off the flash too?
I'm not sure you can. I just had mine sent back to the company for repair because I thought the flash had died. The new camera worked until I turned the sound off. Every time. I'm thinking there's a software glitch. I'm going to notify the company in writing and via phone. Maybe do the same?
Oct 09, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
Finepix S1000fd just suddenly quit working...
I'm not sure how old this is, but I had this identical problem on my Fujifilm Finepix S1500 and the solution was embarrasingly easy and it may be related to this same problem. If your camera has a viewfinder, see if there's an image there. If so, look to see if you have a EVF/LCD button or something similar on the back of the camera. If so, press it. What had happened with me is that my wife likes using the viewfinder for framing and she presses that button to turn off the rear LCD and on the viewfinder. Maybe the button got pressed accidentally. Press it again and it should switch back. Hopefully this is the solution.
May 26, 2009 | Fuji FinePix S1000FD Digital Camera
Jan 28, 2009 | Fuji FinePix 3800 Digital Camera
Flas on camera stopped working?
This is a common problem with this Model. In order to get this replaced you will need to send your camera to the fujifilm repair centre. They shall replace all of the part you require. Please browse to the following web address http://www.fujifilm.co.uk/technical/camera_repair/
Jan 16, 2009 | Fuji Rod Repair Kit
Will not take pictures fujifilm finepix s1000fd
it seems like CCD failure rush to service centre
Dec 25, 2008 | Fuji FinePix S1 Pro Digital Camera
Cameras Logo
156 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
