Garden Logo
A
Anonymous Posted on Oct 09, 2014
Does the 110cc tao tao need 2-stroke oil mixed
Does the 110cc tao tao need 2-stroke oil mixed into fuel
Brian Crowe
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 78 Answers
  • Posted on Feb 21, 2015
Brian Crowe
Expert
Level 2:
Night Owl:
Answers
78
Questions
Helped
56257
Points
135
NO! the 110cc is a 4 stroke not a 2 stroke so you don't mix oil and gas. If you do it will run like s*** if it runs at all.
dspoke
Level 1:
New Friend:
  • Contributor 39 Answers
  • Posted on Jan 25, 2015
dspoke
Contributor
Level 1:
New Friend:
Answers
39
Questions
Helped
9455
Points
96
Unless there is a separate compartment that you add oil to the oil will need to b e mixed with the fuel.
1 Related Answer
Editor925
Dean
  • 285 Answers
  • Posted on Jun 24, 2009
SOURCE: 2 cycle oil to gas mixture ratio
40:1 for a McCulloch 3214.
1helpful
JCB M25 strimmer, bought second hand does anyone know the fuel mix ratio please ?
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
Feb 12, 2019 • Garden
1helpful
Is this a 2 or 4 cycle and whatis the correct oil mix?
I guess the first question is what machine is it? Most chainsaws are 2 stroke and need a fuel / oil mix. If the machine is lesst than 5 years old then a mix of 50 parts fuel to 1 part 2 stroke oil is likely to be needed. Older saws often used 25 parts fuel to 1 part oil. From experience I find that 50 to 1 on the newer saws is too little oil and use a 40 to 1 mix to avoid the expense of having to replace pistons and cylinders!
Sep 23, 2015 • Garden
I have a 1993 Honda 125cc was told to mix gas but these oil in crankcase do I need to mix?
You would never mix any fuel and oil for the crankcase. If it is a 2-stroke engine, the fuel and 2-stroke oil will need to be mixed before entering the cylinder. Some engines have an automatic mixing setup - those have a separate oil reservoir for 2-stroke oil, but it will usually be a plastic tank, located nowhere near the crankcase. On a "4matic" engine, it fires like a 4 stroke, but there is no crank case, and the fuel needs to be mixed like a 2 stroke. What is the vehicle you are referencing? A dirt bike or street bike? It seems the CR125 and NR125 are both 2 stroke engines, so somehow the fuel needs to be mixed with 2-stroke oil. Can you take a picture of the crankcase oil cap?
Is it 4 stroke or 2 stroke
Does it have a dipstick that indicates the amount of oil?
If it has, it is a 4 stroke and does not require an oil/fuel mix.
If it does not have a dipstick, it is a 2 stroke and will require a mix of oil and fuel.
Without knowing anything about your genset, I would think that it is a 4 stroke.
A 2 stroke motor would deliver the power too high in the rev range.
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 • Garden
1helpful
250 2cycle. What is the proper lube for the bottom end?
all you need on a 2 stroke engine is the oil mixed with the fuel. the oil/fuel mixture lubricates your bottom end and your cylinder which is all that moves in a 2-stroke. if it is oil injected then use a 2 stroke oil rated for 50:1 mix. if you gotta mix it manually then just read the jug. hope that answers your question
3helpful
2answers
What fuel does my Echo pb500H use??? 2 stroke oil gas mixture????
2 stroke means that it is a gas mixture. 4 stroke means that there is no gas oil mixture.
Fuel is VERY flammable. Use extreme care when mixing, storing or handling, or serious personal injury may result.
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Do not forget to rate the answer, Thank-you
Need carb setting for tao tao 125c.c. fuel air mix
if 2 stroke then = all the way in and out 3/4 turn
if 4 stroke then = all the way in and out 2 turns
1helpful
Want to no if it takes petrol on its own when fueling or 2 stroke oil added to it aswell
i guess your asking if its a 2 stroke or a 4 stroke right ?
2 stroke engines dont have an oil filler cap , just a fuel filling point, the fuel used in a 2 stroke is just normal unleaded (aus) but you mix 2 stroke oil in the fuel before filling (about 50/1) or whatever it recomends.
4 stroke uses the same fuel but you dont mix the oil with the fuel , it has its own filler point for oil , however you must use a 4 stroke oil with these .
hope this is what you were after.
May 01, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
