Acer Aspire One Netbook Logo
A
Anonymous Posted on Oct 08, 2014
<!-- from fixya rte -->Will not boot up windows xp missing driver - Acer Aspire One Netbook
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Thanks..
tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 • Computers & Internet
Dotmgr missing xp
Hello i hope you mean boot mgr is missing.
This means your windows is damaged, by a virus/malware or a faulty harddrive.
The solution is to install windows again, or make a system repair with the original windows disk.
Here is how to make a system repair:
http://www.ehow.com/how_6970596_fix-windows-xp-boot-
manager.html
A second option, is to download this program:
http://www.hiren.info/pages/bootcd
And burn the ISO file to a disk, and let the pc boot from it.
This cd has a option to repair a damaged boot file.
With this tool, you can save most of the files on the harddrive.
Here is a smart program, that burns ISO files:
http://cdburnerxp.se/
If you have to make a new install of windows, you can download the drivers here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5QL%20PRO&p=1&s=22
Please select your windows system.
Open the driver folder, and click global for download.
Any files from here, needs to be unziped, before you install the driver.
Good luck
One off my drivers is missing would asus be able to send me the recovery disk for an asus x5dij laptop if so this will be handy or tell me how to from peter
What driver is missing? When you bootup, try hitting the F9 key repeatedly, it should boot into recovery console. Also, try F4 if that does not work. For windows XP, you will need the restore CD. For Vista and 7, you can do a repair of the OS through the recovery console. Will the computer boot? Are you sure that it is a Windows OS driver that is missing?
2answers
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
In system 32 boot vbs is missing .how to
Do a repair install from the windows xp disc.
2answers
NTLDR is missing in my computer
Missing NTLDR can be caused by any one of these problems :-
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
Failing to enable USB keyboard support in the BIOS
With Windows XP follow these instructions
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If this doesn't work, then the last resort is to install Windows again, plus the computers device drivers and your programs.
2helpful
3answers
Won't finish boot because bad or missing system32/drivers/ntfs.sys file
There's a few ways to fix this. Easiest way is to just reinstall your operating system. That will wipe out everything and i assume you have data that you don't want lost.
Here is an alternate route. That file is stored on the disk in the I386 folder. Below is a link with the directions.
http://support.microsoft.com/kb/822800
Be prepared, there is still a chance you could lose your data, but the above link gives you the best chance at fixing the problem.
1helpful
File msissing
if you have a boot-able cd with windows xp on ...just enter bios , and advans setings...boot sector and select the first boot device ..the cd-dvd drive ...and after press f10 to save satings ..reboot with the cd ...inserted..and follow the instalation ....the problem might be that your boot from cd is disabled on bios settings...be sure you at liest note somewhere all the names of your sistem drivers..so ya might look for them if needed or identify 'em from your drivers cd-es. Good luck !
Missing or corrupt driver
You sould be able to obtain this from your i386 folder, follow these instructions. http://windows.ittoolbox.com/groups/technical-functional/windows-xp-home-l/xp-wont-boot-up-system32driverspcisys-406490
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
