Due to video hardware and other malware,enternet connection also un proper shot down,couple of times that I reboot my netbook due to virus and I choose to defroult settings. now the condition from slow to worse..
The problem with default settings on computers is the pre-loaded software that comes with computers. These pre-loads could cause a system to run slowly. Best fix, hit start button, type "msconfig" in the search bar/command line. Box shows up, hit startup tab, and uncheck the programs you don't want starting up. This means, less programs running, faster running computer. Apply and ok it, wants you to restart/reboot, do so and see how it runs after.
SOURCE: zd8000 - mobility radeon x600 problem.
The ZD8000 is a very nice machine, but if there are no Vista drivers released for it, you're going to be very frustrated by it's performance.
It came loaded with XP right? If it was a factory Vista load, and drivers are missing, the recovery partition should be able to repair the installation. If there's no video driver, I don't know how it's playing the game at all.
In any case, if it came with XP, and you can find no drivers for Vista, your only choice seems to be to return to XP. It's not as visually stimulating, but much faster in general, especialy for this machine.
Hope this helps
Good luck
SOURCE: lsass.exe Insufficient resources to complete API
In safe mode it does the same reboot reboot thing? Computer messages are not really reliable as far as fault tracing is concerned. The message given is a close as the PC can come to the right one.It sound as though there is a problem reading the hard drive. Try booting from a bootable CDor flash drive if you don't have a floppy drive, and see it if does the same.Can you get into the BIOS setup by pressing delete on bootup?
SOURCE: Acer aspire 5355 malware virus
You will need a Windows installation disc or a pre-prepared rescue disc from initial startup maintenance. Follow the guide below to repair the OS if you have XP. If you have Vista or 7, then follow the guide up until the point of when the disc loads the windows files, then just hit the repair button and windows will do the rest. If you have XP, you will need to do everything below to effect the repair to the boot files.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
SOURCE: after a virus i had to restore my advent 4213
scan for virus, uninstall all what u dont need, if nothing works then reinstall operating system
SOURCE: Product: Sylvania Netbook (SyNet7WID).
Hello, from what I understand, the netbook doesn't use an Intel-standard processor, so only code specifically for that chip will run, ie, no downloadable plug-ins,java, flash etc. CE itself is based on windows 98. I found a site giving useful overviews on these netbooks, I think they're worth visiting:
tp://bestgadgetnow.co.uk/gadget-news/99-cvs-sylvania-netbook-computer-review/
just don't try to view it on your netbook!
regards,
nicam49
YouTube
freeze can happen due to many reasons. Major reasons are overload on website,
simultaneous running of many programs on your computer, Low RAM, Slow internet
connection or corrupt windows registry.
For
smooth watching of YouTube Videos take following actions:
1. Watch
videos at off peak times, if possible
2. Do
not run other programs while watching videos. They slow down computer in
general by making use of memory.
3. Add
RAM on your computer. More RAM will make easy execution of heavy programs on
your system.
4. Get
better and speedy internet connection. Talk to your ISP in this regard.
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner RegInOut cleaner and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
