Question about Tomtom GPS
What do the symbols mean, gas station, bank, duck decoy?
They pop up along the route, in a little square. Some are obvious, some completely mystify me
compusat
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Points of interest in your current location.
To turn off go to setting and manage pois. remove tick from what you no longer want to see
Posted on Nov 28, 2014
1 Related Answer
spectaculusc
clarke richardson
  • 321 Answers
SOURCE: Will the 205w nuvi find restaurants and gas
Yes it will find any restaurant and gas station along the road.
Posted on Dec 25, 2010
Engine codes
The symbol is the check engine light. If you get the computer scanned for trouble codes you will be able to look for the problem.
May 15, 2013 | Cars & Trucks
What to do if the ducks are call shy?
Let them approach your set silently. Don't hail are greet them at all. After they swing over the decoys and start to leave give them the absolute best hen greeting you can. Let them work back on their own after that and see what happens.
Jan 17, 2013 | Hunting
I have a Signature Series duck call and I have noticed that the call sticks sometimes when I blow into it, is there a way to fix this?
When you finish calling at a flock, pull the insert out of the barrel and blow a sharp burst of air under the reed. This will clear the majority of saliva from under the reed.
Jan 14, 2013 | Hunting
Would you call a Teal the same way you would call a Mallard?
The mallard is the most common duck in the wild so most species will respond some to mallard calling. Your best bet is to mix in some peeps and whistles with your mallard calling.
I have nintendos duck hunt when i cannot kill the ducks but the gun is shooting bullets how can i fix this
Hi jme0007!
In order to help you let me explain to you how the Nintendo zapper works.
The nintendo zapper works by decetcing the light from your TV screen. When you "shoot" the gun the screen goes completely dark for a franction of a seccond display white squared where the targets are. The light emitted by the squares is picked up by the zapper only if it's pointed directly at it. What may have happened is that your nintendo zapper is not working propperly, to make sure of this try "firing" the gun at a strong source of light like a light bulb. If this doens't trigger the gun to work then youre Zapper is broken and sadly the product has been discontinued and they don't offer tech support for it anymore.
Your best chance of fixing it would be ordering repair kits online or buying a new one.
Hope this helped you.
-Luchen
Mar 07, 2011 | Nintendo Duck Hunt for Nintendo
Will the 205w nuvi find restaurants and gas stations along the route?
Dec 25, 2010 | Garmin nuvi 205W GPS Receiver
What does 4 arrow up mean, and the 4 arrow down mean. On the left side the little gas symbol comes on at the top what does that mean?
arrow up means it in four wheel drive high. It is geared high for faster speed. Arrow down is four low and is geared lower for less power at the wheel. U would use this if you are stuck. The gas symbol means you need gas in the truck
Dec 06, 2010 | 2006 GMC Envoy Xl
My engine light came on. i had an OBD2 scan done and the code P0430 popped up. it's nthe catalyst system low efficiency bank 2. on the way home tonight my truck started shaking and vibrating a little at...
The low efficiency bank 2 means that the material inside the catalytic converter is deteriorating and needs to be replaced. FYI. Bank 2 refers to the side of the motor with cylinder number 2 on it.
Sep 27, 2010 | 1998 Chevrolet K1500
Cannot take pictures anymore and lost my pictures in memory card.
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 25, 2008 | Vivitar ViviCam 8300s Digital Camera
GPS Logo
47 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
