Need help in restoring my iPhone 4s after update malfunctioned and is stuck on a black background with apple logo on and is not working. Tried to use iTunes but as partner never installed it on a computer can not use iTunes to restore phone as it will not recognize the phone without phone action. Have tried forcing restore without any success.
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
SOURCE: My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: iPhone stuck on Startup logo
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Resetting the iPhone should not remove or delete any data or settings.
SOURCE: My 3gs iPhone is stuck in restore needed/emergency
Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:Use iTunes to restore the device.
If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup. See this article for more information.
SOURCE: itunes iphone
You will to UNLOCK your phone for your sim card to work.
Use unlock softwares, it always works like Quickpwn and others...
Search google for example : Iphone 3g 3.1.2 unlock
