Question about Refrigerators
Freezer arrived yesterday.Previous one returned to shop after two days as motor running constantly and top element thick with ice above and below. All items frozen but covered in snow.Set temp on new freezer to minimum ( previous set half way - no numbers on dial so have to guess.New freezer iced up after less than 24 hours.
Get the technicians back for a warranty check or get a refund on a faulty product
Posted on Nov 23, 2017
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
SOURCE: Freezer seems as if it is not cold enough
Your sensor is packed in ice and giving false reading (always frozen)
You NEED to defrost. Will take 2hr
Turn off or Pull plug on freezer
Take everything out and put in cooler, brown bags, large bin or boxes to stay cold
Defrost by setting large pail of boiling water in each side bottom of freezer and closing door(s) for 1/2hr
Open freezer, empty pails in sink and use pails to hold large chunks of ice from freezer that will come out easily
Toss out ice chunks
Check sensor to be sure it is no longer packed in ice
Wipe down interior dry
close doors
plug in
wait 1/2hr
reload with stuff you want to keep
Done!
Posted on Mar 26, 2009
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
SOURCE: WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
SOURCE: GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Posted on Apr 25, 2009
Jan 11, 2018 | Blomberg Dishwashers
Feb 03, 2016 | Freezers
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Dec 05, 2012 | Refrigerators
May 17, 2011 | Whirlpool Refrigerators
May 12, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Dec 23, 2009 | Refrigerators
Jul 07, 2009 | Kenmore Freezers
Nov 06, 2017 | Frigidaire Refrigerators
Dec 30, 2008 | GE PTS22SHS Top Freezer Refrigerator
Mar 02, 2021 | GE Refrigerators
Feb 25, 2021 | Refrigerators
53 people viewed this question
