SOURCE: I dont know how to hook up my bose speakers to my
This all depends on some unknown regarding your PC and its hardware and software sound capabilities. At a minimum it probably has a headphone output. That can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver.
The Bose AM5iii is just a speaker system. It needs an amp or receiver to produce the power to drive it. Most PC's are made to directly power only headphones or self-powered speakers.
If your PC has a sound card with Digital Audio Out (usually RCA-looking coaxial SP/DIF); or Audio Line Out connections (usually 1/8" and color-coded for Front L and R; Surround L and R; and Center / Sub), you COULD run those to an appropriate multichannel amplifer or receiver and let IT do the speaker thing for you.
Bottom line: you need intervening amplification to use the Bose AM5iii on a PC.
Add a Bluetooth adapter to your computer.
This is usually done by plugging the adapter
into a USB port. (If a Bluetooth adapter is already built in or attached
to your computer, ignore this step.)
Set up the device so that your computer can find it.
To do this, you must:
Turn the device on.
Make it discoverable.
To learn how to make a device discoverable,
check the information that came with your device or go to the
manufacturer's website.
Install the device.
To install most devices, such as a mobile phone,
keyboard, mouse, or personal digital assistant (PDA), you can use
Bluetooth Devices in Control Panel. If you have Bluetooth wireless
technology installed on your computer, follow these steps:
To install a Bluetooth enabled device
Click the Start button ,
click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Click Add, and then follow the instructions.
