Cars & Trucks Logo
R
ROBERT SMITH Posted on Oct 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 55 plate citreon xzara picasso 1.6 petrol that has an intermittent fault, the engine cuts out when braking, all the dash lights come on and i lose the steering and brakes,it usually starts up
This fault happens randomly every 4-6 weeks, it can be quite frightening when it happens, the engine cuts out, as if it has stalled, and the lights on the dash come on, it usually starts back up first time and runs ok afterwards,no one seems to know what is causing this fault, can anyone give me some advice or a diagnosis please?
onehappyange
Level 2:
  • Expert 46 Answers
  • Posted on Oct 08, 2014
onehappyange
Expert
Level 2:
Answers
46
Questions
0
Helped
10167
Points
137
Take the car to a mechanic before you get hurt!
Testimonial: "That advise is what i already know, and three mechanics have had a look at the car and all say the same thing, they say they need to be there when it happens to find what it is or they can't seem to diagnose the fault that is causing it to cut out. If anyone else has got or had this problem please make a comment and hopefully let me know what the fault is here. Secondly if there is a mechanic who does know what it is then feel free to tell me."
5 Related Answers
Anonymous
  • 76 Answers
  • Posted on May 22, 2009
SOURCE: intermittent misfiring and stalling
this sounds like a definate problem with vacuum check valve on your brake booster or the hose going to booster....that should solve your prob! good luck.......ps----------cheap part...quick fix!
Anonymous
  • 3 Answers
  • Posted on Jun 15, 2009
SOURCE: Dash Board Brake Light comes on
I had the same problem, I put in new brake fluid, changed the shoes and pads. When you brake, does your foot go all the way down to the ground?
Anonymous
  • 74 Answers
  • Posted on Jun 24, 2009
SOURCE: 94 liberty stalls intermintently 3-4 days a week
maybe a loose feul pump connection
jamie
  • 1810 Answers
  • Posted on Jan 28, 2010
SOURCE: 1999 dodge ram 1500 2wd 5.2L gives different intermittent codes
pcm posably but i think i would look at the grounds from the battery to body and bat to engine
Anonymous
  • 3489 Answers
  • Posted on Feb 22, 2010
SOURCE: 2007 aveo misfire faults
gm has a problem with this from way back. double check your spark plugs and if they are not ac delcos, change them. ive seen this time and time again swearing, myself, that there is no way that the plugs would cause this issue. it always comes up with random misfire and usually another 1 or 2 codes misfire codes. put in ac delco, no more codes. let me know
Does the light control module control the brake lights on 07 town car?
American car so i have no idea sorry ,but if its any help they are on a citreon gran picasso ,had to change the fuse plate module which is a computer as well ...just under 500 euros ,wish now i had rewired it manually but it was a autobox as well and wouldnt start without the module working ,which i could have manually bypassed that as well but the the immobilisor cut in ,,,no win no win ,now and to the point of writing this still waiting for my money plus dealers fee for re-programming ,Think i will have to pay a visit with my hammer and nails ,if they can afford to go out on the booze then they can pay me.Sorry for the negative answer
I have citreon xzara picasso and the speedo and mileage meter doesnt work
run the fault codes as these items get the message from a sensor in the transmission.
2answers
Citroen xsara picasso faults
Sounds like ignition timing or needs a new battery/alternator.
Have your system tested for free at Autozone.
07 petrol citroen xsara picasso judder/loss power after 1/4 mile from cold
service the car, put correct engine oil in it and also change gear box oil
1helpful
Citreon picasso 1.6 hdi engine code errors P1166 & P0193
Still i have p0193 fault and no pick computersay fuel rail sensor but i was diconect the first injector electric swich then this pro
The oil light on my citreon berlingo van 1.4 petrol will not go off and the stop light flashes and beeps intermittently. I have put about 3 or 4 litres of oil in and there does not appear to be any leaks...
Have you checked the oil level, is it in the norm?, if its normal and still get light, then possible faulty oil pressure sensor. The brake light... are you disengaging the parking brake all the way?, have your parking brake sensor and oil pressure sensor checked out.
Good luck
3helpful
Citreon picasso hearter blower not working
has your picasso got climate control? if so you probably have a faulty ignition switch
the contacts in the switch which supplies the live to the heater wear and cut the supply
Citroen picasso keeps cutting out twice a week on acceleration
Sounds like an air leak or the tank pump cannot keep up with demand (the supply pump in tanks do give trouble (a pressure gauge between tank and engine would tell, make sure it is visable when driving, I used to tape it to the bonnet with masking tape.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
