The brass ring cannot be reused. You cannot buy it separately but it is inside any 1/4" fittings available in your local adware store.
be sure to cut the end of the waterline and install the ring on a Fresh section. Also, make sure the waterline is lined up with the valve inlet before trying to tighten up.
It sounds like the wire you're describing is the defrost thermostat. The defrost thermostat is responsible for controlling the defrost cycle of the refrigerator. The flat piece of metal with hooks at each end that you mentioned is likely the clip that attaches the thermostat to the evaporator coils in the freezer compartment.
To reattach the thermostat, you will need to follow these steps:
Locate the evaporator coils in the freezer compartment. The coils are typically located in the back of the freezer.
Carefully place the hooks of the clip onto the evaporator coils.
Insert the metal prong on the end of the thermostat wire into the clip.
Ensure the wire is properly seated in the clip and that the clip is securely fastened to the evaporator coils.
Put back the cover panel of the freezer compartment
Check that the thermostat wire is not pinched or crimped and that it has enough slack to move freely.
Plug the refrigerator back in and turn it on.
It's important to note that working with the refrigeration system could be dangerous and it's always recommended to contact a professional if you're not comfortable with the task.
Both
cats and humans have the potential to be allergic to cat litter. If you think your cat is allergic to the
litter the first thing you should do is change the type of litter you are
using. You should try a non-clay based
litter that does not create silica dust.
You may also want to purchase a new litter box; perhaps something made
of metal or ceramic.
You are correct, it sounds like an electrical short happened. I am guessing when it was hit, it caused the cord to get pinched in the metal casing. The pinching must have broken the insulation on the cord and the casing is grounded...therefore, instant short. The unit probably wasn't hurt but will need to have a new cord. If you follow the now unplugged cord to the refrigerators electrical connection, it is probably either held on by crimped connectors. Cut those connectors off as close to the connectors as you can (on the opposite side of the power cord). Follow the path of the old cord and remove it from the unit. A new cord can be obtained from a local appliance store or ordered online from places like applianceparts.com. Put the new cord back in the same path the old cord was removed from. Make sure there is no sharp metal to puncture the new cord where the old cord was pinched.
Hope this helps
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes
would get "warm". The refrig would get a LITTLE cool but nothing to be
of any help.
I solved it though...it turns out there is a "flue baffle" (twisty
little metal thing) that is supposed to hang in the inside of the
baffle. It hangs from a screw found on top of the baffle and it is
supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a
coat hanger, then rehanging it using a new screw. That solved my
problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the
flue, the flue baffle, and the piece of metal holding it here:
Look on p.9, figure 9. Item C is the flue baffle and the wire holding
it. Item B is the screw that was corroded on mine, and ended up dropping
the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution. Thank you, Dave E. (Illeagle) "Your satisfaction is my personal reward"
Are there 2 wires that can be seen? And is it flat looking or is it round cable with silver braided wire with white center insulator with copper looking center conductor? If it is the latter you can purchase screw on connectors at most electronics shops. Example...Radio Shack, Home depot, Lowes etc. Good luck and happy tv watching. Jay
