Question about Brookstone Scanners: iConvert Photo Scanner
I can scan but nothing will save...I've gone into settings! Nothing works,what should I do?
Posted by jkepp87 on
Why wont quotev load?
your computer may already have a title of that name that didn't load properly, this time right click and save file on desktop, then load from there
I have lost 'restore down' in Word.
The function is there, The application data that this function uses is gone. Thats normal. Thats what a Backup is for.
RAM is Volatile when you turn the computer off all data stored in RAM is lost that's why we save to HDD if you don't save to HDD you lose it.
I cannot create a macro in microsoft word 2010
When you open Word 2010, click on the "View" tab. The "Macros" button will be on the far right. Clicking on the button will allow you to create and edit macros.
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Imac to jvc
Hi. A couple of things to try.
Switch everything off. Make sure your connections are sound then switch on the TV. Then switch on the mac. With luck the system should sort itself out. However, I have heard of others who have had nothing but grief trying to get similar arrangements to work.Normally ther Mac does it's own thinking, works out what is at the other end and puts up the display without any problems - other than the picture width being invariably wrong until you find the correct size.
There are no drivers to download - the issue is generally that the TV is not reporting back to the computer the correct resolution and scan rates.
You may have to dive deeper into the TV's menus to locate the means of altering the parameters.
2answers
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
1helpful
Re CanoScan 9950F: I opened Toolbox (v. 4.9.3.4), selected Scan setting "auto mode". Under "Save Scanned Image", I ttyped in a "File Name" , Saved it as JPEG/Exif, For...
Hello
Actually you do have to select a program for working with photographs such as Photoshop, or Adobe Elements, maybe Microsoft Paint or Picasa maybe. Then your scanner will scan and the pictures will be saved and they'll be opened in the photo program you have chosen afterwards.
Brookstone Scanners: iConvert Photo Scanner Logo
Top Brookstone Office Equipment & Supplies Experts
Ekse
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
