Question about SanDisk 4GB microSD High Capacity Memory Card
How do i format my memory card 4gb sanddisk and i have forgoten the password
And i use a Nokia phonen 2710 C navigation Edition
Gopal Datta
    New Friend:
    Problem Solver:
  • 12 Answers
Format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Posted on Oct 12, 2014
5 Related Answers
Anonymous
  • 94 Answers
SOURCE: formatting a 4gb sandisk for a nokia 5200
is ur nokia capable of handling 4gb. pls see the specs.
this is a issue many a time.
Posted on Apr 28, 2008
Anonymous
  • 3 Answers
SOURCE: Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
Posted on Dec 29, 2008
Anonymous
  • 5158 Answers
SOURCE: my 4gb scan disc sd card wont format
http://www.sandisk.com/Retail/Default.aspx?CatID=1668
I believe sandisk makes a special program to format their cards
Robert
Posted on Jan 26, 2009
Anonymous
SOURCE: How do you format a Sandisk 4GB micro sdhc card
It may not work as the 3109c only supports 2G cards. 4G may use a different technology.
Posted on Nov 16, 2009
Testimonial: "Good feedback, my phone would not let me format the disk, probably because it is 4GB."
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jan 26, 2010
1helpful
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
3helpful
I hv forgoten my NOKIA 5130 music express memory card passward. Even memory card is not showing in PC.And from mobile when i clik memory it wants password........ please, tell me the...
The easiest way is to format your MMC from your mobile phone,PC can't see it because is password protected.If you don't wanna loose any information you can take a look here :http://www.mobiclue.com/recover-memory-card-password-from.html
1helpful
Please help me to reuse my nokia2710c because i forgot my password security
1.First switch on your Nokia 2710 Navigation Edition without any sim card.
2. Compose #pw+CODE+1#.
3. The Nokia 2710 Navigation Edition would then display the message "SIM Restriction Off" and will be unlocked!
Thank you
10helpful
I forget my 4gb microsd memory password.how to unlock it
Hey bro, im sorry to inform you that there is no way to recover your memory card without losing your data. But if you are fine with losing your data, then try this out.
Put your microSD in a nokia E-Series phone. I'll suggest the E-65. Now, go to the memory card in the TOOLS folder and select options, and choose FORMAT MEMORY CARD. It will ask you for your confirmation, press yes if you want to, and it will format your card and remove the password. I hope this works for you. Cheers ! I've tried it out. It does not ask you to put in the old password before formatting. It worked for me !
1helpful
2answers
To unlock forgoten password of nokia 5200 memory card
I have the same problem - but if I try to connect the memory card to PC throught SDadapter and Card reader - in windows explorer memory card not opening... How can I format the memory card???
1helpful
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
I hav nokia 5310 and i forget my memory card password
plz insert ur memory card in nokia 6110(navigator) then format the memory card from nokia 6110.ur card will be unlocked
Formatting a 4gb sandisk for a nokia 5200
SanDisk 4GB microSD High Capacity Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Ekse
Mehandi Husain ...
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
