Open the drawer.
Top tub : depress the right hand tub clip and push it back about 30mm. Repeat for the left hand side.
Bottom tub: remove the toe kick (refer section 9.4) and lower tub cowling (refer section 9.5), both optional.
1. If the cowling has not been removed, then the tub clips need to be pushed back about 130mm so the slide clears the cowling when the tub is lifted.
2. Lift the tub off the slides and push the runners back into the product.
3. Releasing the wire from the centre clip on the link assembly allows the tub to be moved further from the chassis (optional).
4. If the tub is being turned over for servicing, rotate it counter clockwise, remembering to remove the baskets first. Removing the handle will prevent it from being damaged.
5. Refit in reverse manner.
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
