Yamaha HTR-6090 Receiver Logo
Question about Yamaha HTR-6090 Receiver
<!-- from fixya rte -->How to connect bose 901 to yamaha htr -6090 - Yamaha HTR-6090 Receiver
Garret Roberts
    Problem Solver:
  • 17 Answers
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 35 watts per channel out of the receiver to power the 901's
Posted on Jan 11, 2015
2 Related Answers
Anonymous
  • 31 Answers
SOURCE: Yamaha HTR-6090: fire hazard?
I would check your Outlets to make sure you have Clean Power and are Properly Grounded. That's usually an Electrical Problem, Not the Equipment. Although Sometimes you get Bad Apple!
Posted on Apr 28, 2009
Anonymous
  • 8546 Answers
SOURCE: How to connect bose 901
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input.
http://products.bose.com/pdf/customer_service/owners/og_901.pdf
Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Posted on Sep 05, 2011
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
2answers
How to connect my bose 901 to rx-v2200
You can do this however you will need a separate power amplifier.
See notes here: https://deercreekaudio.com/blogs-%26-updates/f/connecting-your-eq901-to-an-audio-video-receiver-avr
  1. Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right
  2. Connect your 901 speaker to the power amplifier outputs
The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes.
1helpful
How do i connect 901 Seriees VI Equilizer to a Yamaha HTR-5790 AV Receiver
Let's try this for a third time. Bose AMP OUT to Yamaha MD/TAPE IN.
Bose AMP IN to Yamaha MD/TAPE OUT.
Please rate this solution.
A HTR-6050 Troubleshooting - Receiver Turns Itself Off
Hi Elvis,
Does it turn off at the same time everytime? Is there a timer function that still might be on?
Is it overheating?
My htr-6090 wont let my dock be on zone2
Zone 2 will only work with an analog signal (RCA) If you use a stereo mini to rca adapter from the ipods headset jack and plug it into the VAux on the front of the receiver it will work. Downside to this is the audio is "dual controlled" Volume from the iPod and Volume from the Receiver. Set the volume no further than 70-75% on the iPod then adjust to taste with Zone 2. Hope this helps
Have no sound from my tv panasonic th-58px600u which is hook up to my receiver with an hdmi and fiber optic for the video out into my receiver yamaha 6090
Do you expect TV audio to go TOWARD the receiver in this setup? The HDMI is to get video and audio TO the TV. The BEST TV-related audio will come from the device supplying it, not the TV.
Try this. Take the digital audio from the cable / satellite box into the receiver. Ditto for games or whatever.
After all, what else enters the TV that isn't already connected directly to the receiver?
I have a Yamaha HTR-6090 with a HDMI female output Jack whose heavy cable has "loosened" the connection with the male jack (my guess). It now has to be wiggled and held in position to in order to recieve...
There is a product called hd EZ lock, which acts as a strain relief and HDMI Cable lock. There is a very good chance it will help with your issues. It eliminates stress by supporting your cable from the chassis, and it secures your HDMI Cable, eliminating intermittent signal dropouts.
It is universal and works with most HDMI Cables and HDMI Components on the market, and typically installs in a couple of minutes.
http://www.youtube.com/watch?v=-AyR9higu0M
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
