Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
<!-- from fixya rte -->What are .Remote codes fof sony bravia tv? - Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
5 Suggested Answers
Anonymous
SOURCE: Verizon remote control code for Sony Bravia XBR
jesus christ people are retarded.
Posted on Jan 05, 2008
Chaz93
SOURCE: Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
Posted on Jun 16, 2008
Anonymous
  • 734 Answers
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Nov 17, 2008
Anonymous
  • 27 Answers
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
Anonymous
SOURCE: I have a new Sony Bravia 46inch LCD tv with direct
i have a 46 inch sony bravia that i bought in 2007. recently i have noticed that the screen is showing horizontal lines (purple?) about that come and go. any advice would be greatly appreciated
Posted on Oct 09, 2009
What are the codes to program a sony bravia tv model KDL32L500 from a rca universal remote?
You don't need codes for the television. You need the codes used by the Universal remote. Search the internet for your RCA universal remote, use it's model number.to find the user manual.
The codes are there.
Oct 30, 2014 | RCA Universal Remote Control
I have a sony bravia tv and and rca universal remote need the code numbers
TV/VCR Combo.
For power on, these products require programming TV
codes on the remote control. For Sony, use TV code 0000
and VCR code 0032
Sep 29, 2013 | RCA 3-dev Universal Remote Remote Control
Rc65x not working with sony bravia
Direct TV rc65x code for Sony Bravia is 10000
Setup Instructions
  1. Set the "Mode Switch" to Device 1 (in the case of the rc65x set on TV).
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code above.
  4. Try your new code and tell us how it worked!
    (It worked perfectly for our Sony Bravia using our rc65x remote)
    & Goodluck!
    http://www.ezremote.com/setupcodehelp/DTV2/dtv.html?product=DIRECTTVRC65SW2009#search
Jul 25, 2012 | Directv RC65X Universal Remote Control
Need a remote contol code for sony bravia kdl 37U4000 for skyplus HD remote control
Hello
Remote codes for Sony TV with Sky Plus remote are:
038
533
679
505
533 038 039 064 102 130 505
Ok.
Jul 06, 2011 | Sony BRAVIA KDL-37U4000 37 in. LCD TV
Need remote code for TV Sony Bravia KDL-46W4500
I tried out a few of the numbers that were posted and the "0000" number worked.
Thanks anyway
Jan 03, 2010 | Yamaha YSP-1 System
Programming remote to operate Sony Bravia TV
You can find your codes here:
www.tvcodes.com
OR
www.remotecodelist.com
OR
www.remotecontrolsrus.com
May 10, 2009 | Televison & Video
you should press 10000, which is the code
Mar 06, 2009 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Jan 19, 2009 | Yamaha YSP-1 System
3. Press tv again
Sony Code: 0000
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
