Question about Dremel Variable - Speed Multipro Rotary Tool 395
Craftsman rotary tool doesn't lock down on the bits.
I have used this tool for years, but when I took it out to use it this weekend, I couldn't get the collet nut to lock down on the bit. The shaft of the bit just falls out no matter how much I tighten the collet nut. I bought a new collet nut set, but that didn't help. None of the bits I have lock into the device. The motor runs fine, the bits just fall out and won't spin if I can't lock them in place. What's going on? I'm using the tool the same way I always have.
Posted by micromed on
John Rogers
    New Friend:
    Problem Solver:
  • 7 Answers
Sounds like you may have stripped the thread on either the collet but or the shaft. When you've tightened the collet nut does it go loose again?
Posted on Sep 03, 2014
dewey wyatt
  • 202 Answers
The collet is either the wrong size for the shaft on the attachment or is missing alltogether
Posted on Jul 07, 2009
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
I took apart my Dremel 395 Type 3 and the spring popped out for the shaft lock. Where does the spring attach to?
It doesn't attach anywhere, that's why it popped out. It should just fit in a recess, pushing the lock button outward.
Sep 10, 2011 | Dremel Variable - Speed Multipro Rotary...
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
I am trying to use a portable rotary tool but i can't remove the drill bit that's already on it, there isn't a reverse button on the tool so i am at a loss for how to remove it. can you help me?
You have a wrench that fits the chuck and a stop button that locks the shaft, loosen that chuck up and pull out the old bit, if it is frozen or rusted, try poking it against something solid, make it go in to break it loose, then pull out the bit. If that doesn't work, soak it in blaster or some other penetrating oil, then try the same again. Hope this helps.
May 23, 2010 | Craftsman Tools & Hardware - Others
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
How to use the collet wrench
There should be a spindle lock near the collet end of the tool. Engage it and then put the wrench on the collet nut and loosen the nut. If the bit is stuck just tap the end of it slightly to loosen it and it should come out. Reverse this process to install a new bit...hope this helps you...Jeepfxr
Oct 18, 2009 | Craftsman Tools & Hardware - Others
Router Question - tightening a bit on router
If you are asking how much to tighten it then it should be a little more than snug, if you want to know how to lock it to tighten I would need the model number to find out what they use. Please let me know and I will try and help
Oct 09, 2009 | Craftsman Tools & Hardware - Others
I have a Durabuilt rotary tool model S1J-FE2-10 that I can't seem to get to hold a bit. The directions say to hold the spindle lock button down and put the bit into the collet and tighten. I doesn't hold...
User Error! There are different diameter collets. I bet you are using a larger diameter bore collet than the bit outside diameter. Collet can be purchased at any hardware store. To remove unscrew nut, remove collet and replace with proper diameter.
Aug 28, 2009 | Tools & Hardware - Others
Cannot remove attachments
your lock mechanism has worn out
I use a small drill bit towards the end of the rotary tool where
the air fins are and insert the drill into the fins to lock it down
then use the wrench to loosen .
make sure it's unplugged and don't be too forceful
Mar 23, 2009 | Black & Decker Tools & Hardware - Others
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
908 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
