Question about Kenmore HE2 Plus Front Load Washer
Drum wont turn, Do I need a belt?
All cycles work but drum wont turn on wash or spin
Christie Parker
    Habit-Forming:
  • 12 Answers
To recall an error code:
  • Wake the machine by pressing any button
  • Wait 5 seconds
  • Press and hold the Start and Pause Cancel buttons simultaneously
  • All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed. A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
  • Error code - Fault condition
    E11 Fill time too long.
    E13 Water leak in tub or air leak in air bell.
    E14 Reed switch.
    E21 Water not pumping out fast enough.
    E23 Drain pump relay on control board failed.
    E24 Drain pump relay on control board failed.
    E31 Better models. Pressure sensor not communicating with control board.
    E35 Better models. Pressure sensor indicates water overfill.
    E41 Control board thinks the door switch is open.
    E42 Door remains locked after cycle is completed.
    E43 Control board problem.
    E44 Control board problem.
    E45 Control board problem.
    E46 Control board problem.
    E47 Board thinks the door PTC circuit is open in spin.
    E48 Board thinks the door PTC circuit is closed.
    E52 Bad signal from tacho generator.
    E55 Motor overheating.
    E56 High motor current.
    E57 High current on inverter.
    E58 High current on motor phase.
    E59 No tacho signal for 3 seconds.
    E5A High temperature on heat sink.
    E5B High temperature on heat sink.
    E5C High temperature on heat sink.
    E5D Communication problem.
    E5E Communication problem.
    E5F Communication problem.
    E67 Input voltage on microprocessor incorrect.
    E75 Better models only. Water temperature sensor circuit.
    E76 Better model only. NTC temperature for the cold water valve over the limits.
    E95 Communication error.
    EB1 Incoming power frequency out of limits.
    EB2 Incoming line voltage above 130 VAC.
    EB3 Incoming line voltage below 90 VAC.
    EF1 Clogged drain pump.
    EF2 Too much soap.
  • Hope this helps. When mine didn't spin it was the door switch, I ordered the part from Lowe's and it was an easy fix.
Posted on Oct 08, 2014
Eric Lim
    New Friend:
  • 33 Answers
If motor turning, belt slip, bearing could be broken. It's not easy to change the bearing, but first try spin the drum, if it can spin freely, then tighten the belt tensioner by adjusting the motor mounting screw.
Raymond Richards
    Master:
  • 407 Answers
It could be a direct drive. If it is a belt you will have to take it apart anyway so why not take it a part and look? If it is a belt it will probably be at the bottom of the housing and easy to spot. If it is something else you will not see a broken belt.
Posted on Oct 09, 2014
lesB
    New Friend:
  • 62 Answers
Can you hear the motor turning? If you can then the belt sounds likely. If not it could be a bad motor, or relay or a bad connection or contoller.
cpsutherland
    New Friend:
  • 4 Answers
Try hand moving or spinning the drum for at least 6 revolutions. Try your cycle again. If that doesn't work you may have a slipped belt and will need a technician.
5 Related Answers
Anonymous
  • 1937 Answers
SOURCE: I have a top loading Kenmore 80 series Model #
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Posted on Sep 29, 2009
Testimonial: "The information is very detailed and I'm sure will be helpful. We'll know more once we check for damages to the springs on the cams."
Washer_tech
Geoff Siegel
  • 164 Answers
SOURCE: washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Posted on Aug 16, 2007
Anonymous
  • 209 Answers
SOURCE: Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Posted on Sep 19, 2007
Anonymous
  • 113 Answers
SOURCE: Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Posted on Mar 03, 2009
Anonymous
  • 92 Answers
SOURCE: Our Kenmore 970-C40042 front loading washing
this sounds very much like the bushes have worn out on the motor,they cost about £10.00 to replace and easy to fit,hope this helps.
Posted on Jul 15, 2009
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Ge washer WSXH208 drum wont turn
Take back panel off and see if the belt broke or possibly came off the pulleys. Should go from motor pulley up and around big pulley on drum back.
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
3helpful
2answers
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
2answers
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
4helpful
2answers
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
Kenmore HE2 Plus Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
