Question about Brother DCP 115C All-In-One InkJet Printer
Green photo capture button flashing with unable to print flashing too.
1 Related Answer
philden_76
phildens tañeca
  • 43 Answers
SOURCE: After Paper jam Printer Flashing between unable
check again if theres something left in the area which the jam occurs then re start ur printer
Posted on Mar 03, 2011
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Mar 03, 2011 | Brother Laser Printer
Take pictures, reads unable to recognize files, and doesnt even show i have taken a picture
The camera may require manually opening the shoot lense to achieve flash to capture pictures. Observe the camera buttons for every complementary buttons that may require activation prior to photo shoots. Usually smaller cameras with lenses may require manual lense adjustments prior to every photo shoot.
Feb 03, 2011 | GE X5 Digital Camera
Waste ink absorber is full and needs to be replaced. how do I do about it. Unable to print
This is all procedure, no need to disassemble printer.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 28, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Green power light is flashing and red light next to it stays lit
A flashing green on printer light generally means its waiting for a command for instance, push print, stop etc... also check that the pause button has not been pushed. if so depress again to release printing process
Jul 11, 2010 | Epson Stylus Photo 1280 InkJet Printer
K618i Camera fail to capture photo
if your flash is on turn it (off)
if your flash is off turn it (on)
Oct 07, 2009 | Sony Ericsson K750i Cellular Phone
The resume button was continually flashing and would not print. After turning on and off several times, checking ink and making sure the lid on printer was down, the flashing stopped but still won't print,...
On that machine the resume button flashes a certain number of times and then the green power light flashes, you need to count the flashes inbetween the green flashes to know what the problem is. That count tells a repair shop what is wrong.
Aug 12, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Not printing
hi i have similar problem .error code 5a .can you help ?
Oct 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
75 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
