Question about Electronics - Others
I am not able to remove disc protection
The device has been working normal condition. Usually I copy a movie in the pen drive insert my DVD playing the movie. One day I did the same activity the movie stopped after some time. I try to again and again. But I can't play the movie. I removed from my DVD and insert my pc and try to format. The window gave the message the device is disc protected. Moreover I cant copy any file.
Nanny
    Genius:
  • 2,351 Answers
The best DVD protection removal program I'd like to recommend to you is Leawo DVD Copy. It's the perfect program to remove DVD copy protection Windows 7 users could use. It can remove the DVD protection when copying the DVD to your computer hard drive or to another disc and create a protection-free copy of your DVD. Its support for 1:1 lossless DVD backup would allow you to create a backup that's exactly the same as the original disc regarding quality.
Posted on Nov 20, 2019
Gopal Datta
    New Friend:
    Problem Solver:
  • 12 Answers
Format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Posted on Oct 12, 2014
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: Write protection in pen drives
hi,
could you mention the brand of the pen drive.
anyway for deleting the files . try this--> right click the file and click properties. now check you "read only" (ie. dis-select it ) and select file or folder is ready for archive.
now try to delete it.
hope it helps. and after knowing your brand and model of your pen drive more information can be given.
regards
bzoy
Posted on Jan 09, 2008
Anonymous
  • 35 Answers
SOURCE: Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Posted on Nov 21, 2008
Anonymous
  • 47 Answers
SOURCE: I can't format my pen drive.
Click > Start > RUN > type "CMD" Then
Type "CHKDSK" and type o your Pendrive and "/F". Ex. chkdsk Q: /F > Enter
Ok, You see many msg error. OK!
Now, you remove your pendrive and plug again.
Try to format.
It works well.
Thank You
Posted on Aug 06, 2009
Anonymous
  • 350 Answers
SOURCE: i hav 4gb pendrive of transcend.It cant be formatted becoz of write protection.How to remove write protection?
If you do not have a write protection switch on the drive itself, you must download utility called Jet Flash recovery Tool form transcend website and
use it recover your pen drive.
you can also download the recovery tool from this link also:
http://rapidshare.com/files/261372396/JetFlash_Recovery_Tool.zip
Please vote appropriately and leave a response. I hope this helps and good luck.
Posted on Oct 29, 2009
Anonymous
  • 78 Answers
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Posted on Jan 08, 2010
DVD Fab isn't copying DVDs anymore.
Try. reinstalling your media program.
Nov 20, 2016 | Televison & Video
Tip
How to rip protected DVD
Commercial DVD titles are often encrypted, which prevents you from either copying them to your hard drive, or playing the resulting files even if you are able to copy them.<br /> What can we do to solve this problem? I recommend a FREE applicant for solving this problem-DVD Smith Movie Backup. This small applicant is a DVD Decrypter and DVD copying software to copy entire DVD movie to hard disk and removes all the protections(CSS,RC,RCE,APS,UOPs and Sony ARccOS) while copying.<br /> <a href="http://www.dvdtoitunes.net/">dvd to itunes converter</a> can rip DVD and protected DVD to any video formats for enjoyment. You can also rip DVD to any mobile device, like iPad, iPod, iPhone, Zune, PSP ect.<br /> Below is the full instruction of <a href="http://www.dvdtoitunes.net/dvdtoitunes-guide/how-to-rip-protected-dvd.html">how to rip protected DVD</a> to your hard disk.<br /> The operation of DVD to iTunes is very simple. After only several steps, you can backup protected or unprotected DVDs to the hard disk.<br /> Step 1: Load DVD Movie<br /> Insert your DVD disc into your DVD-ROM and then run the program. Click the "Open DVD" button and add the DVD file. You can add DVD Folder, DVD ISO Files and DVD IFO Files as well.<br /> Step 2: Output Settings<br /> You can rip Protected DVD to any video formats. Click "Profile" drop-down list to select an output format. You can set the Crop and Resize option in this step.<br /> Step 3: Rip Protected DVD<br /> After all the settings are OK. Click the "Convert" button to start conversion. When the conversion is done, you can load the converted protected DVD to your mobile device for enjoyment.<br /> Related topic: <a href="http://www.dvdtoitunes.net/dvdtoitunes-guide/drm-protection.html">drm protection</a> <a href="http://www.dvdtoitunes.net/itunes-drm-remover.html">drm remover</a><br />
on Feb 12, 2011 | Computers & Internet
Tip
Blu-ray/DVD/Flash to HTC EVO 4G Conversion,Rip Blu-ray to HTC MP4 Great news to...
Great news to HTC EVO 4G users comes when Sprint announced the update of smartphone operating system to Android 2.2. Sprint is the first carrier to offer Android 2.2 to HTC EVO 4G with Flash support. However, there is no Blu-ray support to Sprint Supersonic HTC EVO.
Aunsoft Blu-ray Ripper is the right Blu-ray to HTC EVO 4G converter for you to enjoy Blu-ray movies on smartphone.
Rip Blu-ray to HTC EVO 4G:
You can load Blu-ray disc and DVD disc to the converter, and load BD/DVD movies from computer hard drive with disk structure.
Downscale 1080p Blu-ray to HTC:
Convert high definition Blu-ray movies from 1080p to 800x480 to fit the screen of HTC EVO 4G.
Remove copy protections:
The HTC EVO 4G converter removes the copy protections like BD+. ACCS in Blu-ray disc, CSS, region code in DVD disc, so that there is no pixilation on the output videos, and ensure smooth playback on HTC EVO 4G.
Why choose Aunsoft Blu-ray Ripper as Blu-ray to HTC EVO 4G converter?
- Convert Blu-ray 1080p to Sprint HTC EVO 4G at 800x480.
- Remove copy protections to enable smooth playback on HTC EVO 4G.
- Rip DVD movies to MP4 for HTC EVO 4G.
- Support disc conversion and DVD-file structure conversion.
Free Download Blu-ray to HTC EVO 4G converter for your Windows computer with OS like Windows XP, Windows Vista, Windows 7. It is no longer difficult to play Blu-ray movies on HTC EVO 4G. If you are using Mac computer like iMac/MacBook Pro, you may try the Mac Blu-ray to HTC EVO 4G converter.
on Aug 09, 2010 | Cell Phones
Anyone know how to copy movies I purchased on itunes onto dvd so I can pop um in the dvd player?
HI,
Purchase Tunebite software. You may also download it, but will onlyreceive the first thirty seconds of video as a trial. Completeinstallation wizard, which can take several minutes.
Launch Tunebite software and click on the "Add" button. This process will allow you to load your iPodmag-glass_10x10.gif video library into Tunebite.
Click on "Convert Files" tab and place cursor over "Convert File to"drop down bar. Select WMV7 (1024kbps). Select "Start" to beginconversion process. The Digital Rights Management copyright is nowsuccessfully removed.
Download Aimersoft DVD Creator. Run and launch software. Simply click "Load Video" and drag videos onto storyboard.
Click "Burn". Select the "To DVD" option and adjust settings to NTSCfor television viewing. Insert a blank DVD-R/RW disc into DVDrecordable drive and record.
Jan 23, 2010 | Apple iTunes
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Tip
How to Copy DVD on Mac
This step-by-step tutorial will show you how to use Copy DVD for Mac to backup DVD on your Mac (tiger and leopard). With DVD Copy for mac iSkysoft, you can even copy your DVD movies and remove their protections with just a few clicks.
Step 1: Select Copy DVD Mac Source
In the 'Select Source' field, click and select 'Select source DVD folder'. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step 2: Select Copy DVD Mac Method
Copy DVD Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the 'Select DVD Copy Method' field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the 'Output DVD Folder' option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step 3: Program Settings
Set Buffer Directory: Specify a directory on your hard disc as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard disc that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step 4: Start copying
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, DVD Copy for Mac iSkysoft will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Jul 15, 2010 | Computers & Internet
Tip
ISkysoft DVD Copy for Mac Guide
Want to copy D9 and D5 DVD movies on Mac OS X? iSkysoft DVD Copy for Mac is specially designed for Mac OS X users to lets you copy your DVD movies and remove their protections with just a few click. iSkysoft DVD Copy for Mac allows you to output DVD folder and directly burn your DVD movies to new DVD discs with no protections.
Step1. Please download iSkysoft DVD Copy for Mac; you can know more about it by visiting here.Then install the software and run the software.
Step2. Select DVD Source
In the “Select Source” field, click and select “Select source DVD folder”. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step3. Select DVD Copy Method
iSkysoft DVD Copy for Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the “Select DVD Copy Method” field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
Step4. Program Settings
Step5. Start Copying DVD
Click the Start button to start copying your DVD movie and/or burning it to a new DVD disc.
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, iSkysoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Mar 31, 2010 | Computers & Internet
I wish to copy a DVD with .DAT file or other video
First to make it clean, you are not allowed to make copies of the original DVDs. They are under Copyright law.
You may make a copy of original DVD for home/backup purpose.
Put your DVD in your drive.
If some movie playing software opens, than close it !
Plug your USB device and open it.
Create a folder with the name of movie, and open it !
Open My computer, right click on your DVD Rom device, and click Open.
You will see contents of the DVD. Press CTRL+A click and drag it to the new folder on your USB !
Later you can watch the movie from the USB.
If you want to copy a disc to antoher you need some software like Nero and you should choose a DVD Copy.
Please note that you will need a Disc with tjhe same size as the original (4.7 or 8.4 GB) and also, note that some DVD movies are protected and can not be copied, or that you might not be able to watch a copy of it.
Regards.
Mar 26, 2009 | HP Pavilion dv6000z Notebook
USB 16 GB transcend says disc is write protected!!
You should try to delete the partition in the Transcend memory stick and creat a new partition. You should copy any files that you need off this memory device before you re-partition it because you will lose all the data that is stored on the device.
Go to the Control Panel - Administrative Tools - Computer Management - Disk Magament.
Scroll down until you see your removeable device the 16Gb memory device, click once on this, It may not show it as Healthy.
Right click in this disk (make sure you do not select the C drive) and click on Delete Partition to remove the partition.
Right click on this unpartition drive and Create a partition.
You may not have to format this partition, it should now show this as a healthy drive.
Exit out of Disk/computer Management and Control Panel.
The USB drive should now function normally.
Mar 04, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 | Computers & Internet
Electronics - Others Logo
226 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Electronics - Other Expert? Answer questions, earn points and help others
