Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
<!-- from fixya rte -->My mute button is not turning on sound - Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Why can't I turn off the mute function?
Usually, mute is turned on and off at the remote. Press once to mute, press again to turn sound back on.
Sep 29, 2015 | Sony Audio Players & Recorders
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
My volume and mute button has stopped working all other buttons are functioning properly
Press the mute button and then turn up the volume button. If no sound still then press the mute button again. If we are talking about a Remote, then change the batteries.
Apr 08, 2010 | Audio Players & Recorders
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
No sound
Check the speaker icon in the taskbar at the bottom, if there is an X then it is muted. Right click to unmute.
Also as it is a laptop there may be a mute button on the keys using the function button and a typical mute icon on a key or even a seperate button altogether.
Mar 18, 2009 | Microsoft Windows XP Home Edition
No sound to TV when MUTE button is turned off.
eeprom ic after you replace it you will have to have service menu to reset hori sink .
Dec 12, 2008 | RCA F32665 32" TV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
