Cameras Logo
A
Anonymous Posted on Oct 07, 2014
Where can i get kodak dc265 driver
Kodak no longer supports dc265.
Mark S Smith
Level 3:
Master:
  • Master 601 Answers
  • Posted on Oct 07, 2014
Mark S Smith
Master
Level 3:
Master:
Answers
601
Questions
Helped
84498
Points
1626
2answers
I have Kodak Dc265 Zoom Digital Camera but i don't have the installation CD.....PLz help me where can i download the driver and software so tht i can connect my camera with PC and can transfer pics to my...
The camera software upgrade can be found at:
http://www.userdrivers.com/Digital-Camera/Kodak-DC265-Zoom-Digital-Camera-Firmware-Upgrade-1-03/
The manual can be found at:
http://www.kodak.com/global/plugins/acrobat/en/service/digCam/dc265/manual/dc265english.pdf
The drivers can be downloaded at:
http://www.driversquad.com/driver.php?option=h&prodid=7317&cust=kodak%20download_AD_search.aol.com_&channel=h&subid=201_US*DR_SITE_ID&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
Kodak will sell you the software at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=164/150&pq-locale=en_US&_requestid=33317
Kodak also makes the poiont that you cannot install the software from a CD that you have created, presumably from a copy operation.  Based on that, I would say you would need ot copy a backup CD using identical mapping in order to be successful.
I could not locate anyplace that offered a download of the CD software.  Hopefully some of the other links provided will satisfy your problem.
Good luck.
WHAT MODEL CARD NEED FOR KODAK D 265 TELL ME PLEASE
The DC265 is no longer supported by Kodak thorugh chat, email, or other means, only a manual on it exists for download:
http://www.kodak.com/global/en/service/products/ekn006593.jhtml?pq-path=691
I didn't really see anything regarding a card needed to take pictures so I assume it just has internal memory for the camera.
Kodak DC 260 The camera does not turn on. For some seconds the power light blinks green, then it changes to blinking red and the diplay shows ''E 11''. Then it turns off.
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Can't download my pix to my computer
monkey1,
As this is an old post, do you still require help?
Have you contacted Kodak tech support?
Apart from the Kodak software to connect the camera, you could use a USB card reader.
Take the memory card from your camera and put in the card reader.... it transfers MUCH faster than directly from the camera too.
Need driver for cx7330 for OS 9.1
Are you sure the camera needs sfotware of any sort. OS9 s Mac I appreciate-] but the USB protocol says no drivers needed and that should apply I would have thought to Mac or PC
Kodak dc 265
the firm ware is not upgradable I tnih- Kodak Tech help may have a different answer have you asked? Blurred images could be nothing more than being inadvertantly set to Macro or low light or being 'stuck' on either of these. have you checked?
Kodak dc265 zoom digital camera
Hi: What's happening to your camera is not normal but, I think the real probelm it's in the batteries. You're using 4 AA NiMh bateries all charged? How many mAh do the batteries have? I think that your batteries may be vitiated and that's what's causing the mal function. I sugest that you buy new 4 AA NiMh with 2500 mAh and try with those... or ask a friend to loan you :D Regards
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
