Question about Nintendo DS Lite Console
When my ds closes it turns off
When my ds turns on it turns of if it is closes or
a 45 dergreese angle
Posted by susan_cunnin on
Anonymous
  • 4 Answers
Your an idiot.
It's called sleep mode, just open it up again, genius.
Posted on Jul 04, 2009
My bevel angle crank will not turn. The angle is locked in the 45 degree position and will not move no matter how hard I turn the handle.
I had that problem with my table saw. The gears for the angle adjustment had become jammed with saw dust and they would not function properly until I dug out all of the crud so they could be turned. You might try that remedy. Good luck.
Dec 26, 2017 | Saws
What is the dwell angle on a 3f engine if point gap is 18 thou
dwell angle is the no of degrees rotation between points closed and points open and for example on a 4 cylinder engine ( 4 lobes =90 degrees the dwell would be around 45 degrees available
there is an adverse relationship between point gap and dwell angle
the closer the points the bigger the dwell and conversely the bigger the gap the smaller the dwell angle
in a distributor the point gap of 18 would have a large dwell angle and that affects ignition timing
in your workshop manual there will be a dwell angle specification and if you set the points at .020 " that will put you close to the dwell angle specification
from there you adjust the gap to obtain the dwell setting
after yo have the dwell set , adjust the ignition timing
there is plenty of information on dwell angle, /point gap if you type in ---dwell angle to point gap relationship--
Aug 16, 2016 | Cars & Trucks
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
My saw cuts at angle to the right
When My Pioneer did that a close inspection found a wire edge on the top rear and bottom front rails of the bar. A flat file used at 45° to the rail removed it. The bar once again cuts true. The only other likely possibility is the chain is sharpened at different angles. HTH
Lou
Dec 04, 2009 | Homelite ZR10926 16 Chain Saw
DS Lite, the top screen goes black when opened the whole way when the game is opened to a 90 degree angle the screen is clear and works fine.
There are a few things that could have happened, the most likely that one of you cable clips is loose, and when you open it fully, it pulls it out just enough so that the connection is lost.
Your going to need to open your DS, (the forms at www.powergamingparts.com are the best forms to find these instructions) then just disable your clip, and reinsert it, and then close the clip, and put you DS back together. Just ask if you need any additional help.
Sep 27, 2009 | Nintendo DS Lite Console
How to draw a cross with 17 pins outside and 16 inside
the cross needs to be drawn at an angle. start at the pin on the far left 3rd from the top and take the line to the top row 3rd one in. Take it down at a 45 degree angle one pin and then back up at a 45degree angle to the 3rd pin from the top left (in a V shape) then take the line (you should be 3rd pin from left on the top row) take it to the 3rd pin down on the left and repeat the V indentation, repeat around the pins and you are there....
Jan 03, 2009 | Nintendo Professor Layton & the Curious...
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
DS Front Focus Problem
I had a similar challenge with my D, the difference being it back focussed, it only happened with one lens, my FA* 24/2.0. Strangely, after returning them both to Pentax, it turned out to be the body, not the lens, which was kind of bizarre! Eventually after 3 months of backwards and forwards with the body, Pentax replaced it with a new one. Everything is now fine (apart from 1 hot pixel, which I can cope with). I pursued the matter with politeness and accepted the delays, the staff at Pentax UK were MOST helpful, but tied by company rules that the repairs had to go back to Germany each time, which added probably 80% to the delays. I ran with film in my MZ-S and digital on my Fuji 602 (backup digicam) while it was being sorted. I must admit I'm considering adding another body, but will probably wait until the year Pentax decide to bring the out D replacement.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Nintendo DS Lite Console Logo
88 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
