Question about Visonik Car Audio & Video
Manual for visonik v417sx
Owner's manual for Visonik v417sx amp
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: visonik amps turn on into protection mode(where green not red for three days)...switched over the wires to some sony amps and they dont even turn the hell on
the fuze could be blown on the amp or the speakers are to much power for the amp at full power so try to turn the amp to half and not to turn the speakers all the way up,.
Posted on Nov 27, 2008
Anonymous
  • 655 Answers
SOURCE: visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Posted on Mar 25, 2009
Anonymous
  • 655 Answers
SOURCE: DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
Posted on May 10, 2009
hoyzee1
  • 150 Answers
SOURCE: Visonik V12D4
i would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Posted on Jun 18, 2009
Anonymous
  • 6 Answers
SOURCE: WHY DOES MY AMP CONTINUE TO BLOW ITS FUSE ..I HAVE
go with an 8GA wire and see what that does for you because the battery is sending power to an amp but the amp cannot transfer all of that power anywhere without speakers being ran to it if you think 8GA is to small then try running a fuse in with your 4GA
Posted on Jun 25, 2009
Amp wont turn on..Visonik vb212pkw
Well you have a high impedance path to your amp. If you have an inline fuse that should have blown. Car batteries don't have a current limiting feature HA The only explanation would be that the amount of current passing through the wire is causing a large voltage drop due to a large impedance. What gauge wire are you using? Here is an example.
18 ft of 8 gauge wire would have to be passing about 400 Amps of DC current to yield a voltage drop of that magnitude. The wire would melt and all hell would break loose. So there has to be a break in your wire somewhere.
Dec 18, 2009 | Visonik VB212PKG Car Audio Amplifier
I have a visonik V8EQ, that i just bought last weekend, & it didn't with a manual or install instructions, i tried going to web site i found on warranty card, but i get an error message. i searched the...
I tried my best but was not able to find one also. I was able to browse their website and its not there on the downloads page.
Your best bet would be to contact them at [email protected] The shop where you bought the device should give you the manual. How will you install it if you don't have a guide.
Best of luck!
Aug 07, 2009 | Visonik Audio Players & Recorders
WHY DOES MY AMP CONTINUE TO BLOW ITS FUSE ..I HAVE A 4GA AMP KIT ON IT ......IS THAT TO BIG ..I DONT EVEN HAVE ANY SUBS HOOKED TO IT ..VISONIK V107SX
Jun 23, 2009 | Visonik V117SX Car Audio Amplifier
Need to know what connections for 6 pin input port
honestly anything made by visonik is **** and i wouldent try wiring it like that it could have bad consequences do rca or call visonik and order a replacement
Apr 26, 2009 | Visonik V117SX Car Audio Amplifier
Visonik amp problem... amp goes in and out of protection
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Protection light on Visionik V204XT
What happens if you have the positive 12v wire from the battery connected?
Nov 16, 2008 | Visonik V204XT Car Audio Amplifier
Smoke coming from visonik v4218
Generally, smoke means the power supply FETs have failed. There may be other problems that could have caused it to fail. It will need to be repaired.
Let me know if you have any other questions.
Aug 08, 2008 | Visonik V4218 Car Audio Amplifier
Intallation of amp
Don't! The amp will draw many more amps than what the 12V outlet (like a cigarette lighter) can handle. Most amps are wired directly to the battery (for the +12V) with a 30A or higher fuse (reference the owner's manual)
Mar 18, 2008 | Visonik V2000T Car Audio Amplifier
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
